n scale pcc trolley
Discussion in 'N / Z Scale Model Trains' started by csxengineer, Feb 8, 2005.
  1. csxengineer
    csxengineer Member
    bachmann pcc trolley, would it work on atlas code 55 or will the flanges hit the ties? Anybody make a realistic/affordable pcc in n scale? Thanks.
  2. davidmbedard
    davidmbedard Member
    Here is a simple question.....do you have access to a drill?
    If you do, you can remove the wheel sets off of any locomotive, insert the axel into the drill and then use a file to slowly work the flang down....
    just a thought.....and more than likely, NO, the bachperson trolley will have uber huge flanges...and probably be out of gauge.
  3. interurban
    interurban Active Member
    I have seen European N scale traction running at the Toronto Christmas Show last year. There may be PCC out there.
    I will search and get back soon.
