N-scale from inches to feet
Discussion in 'N / Z Scale Model Trains' started by rob164, Feb 25, 2004.
  1. rob164
    rob164 Member
    Im making an N-scale layout. I need to know what the inches in N-scale are to what feet are. Can someone please tell me? Thanks,
  2. ezdays
    ezdays Out AZ way
    Just convert you full-scale measurement into inches, and divide by 160. Your answer is in real life N scale inches.
    For example, a 40 foot boxcar would be 480 inches. Divide that by 160 you get 3 inches.
  3. rob164
    rob164 Member
    O, cool thanks! :D
  4. billk
    billk Active Member
    And one furlong is 49-1/2" in N scale, so if you building a 4 ft X 8 ft layout, it's about 1 X 2 furlongs. :D :rolleyes:
  5. rob164
    rob164 Member
    thanks...im making a mountain in my layout, how high should i make it?
  6. cidchase
    cidchase Active Member
    Hi rob,
    Just don't go much over 180 feet, if you're wanting to stay
    true to the prototype. :D :D :D
    About 1/4 furlong or so. :thumb:
  7. rob164
    rob164 Member
    Thanks cidchase!
  8. cidchase
    I think I feel just like Phil Henry
  9. rob164
    rob164 Member
    what is the inch to foot ratio of N scale?
  10. Will_annand
    Will_annand Active Member
    12 inches equals 1 foot, at least it did before we went metric. :D
    160 N Scale Feet = 1 real Foot
    13.33 N Scale Feet = 1 real Inch
    I am having to learn all this new stuff, as I change from HO planning to N Scale planning for my new layout.
    I could not get much in a 5x11.5' alcove in HO.
    But can get the entire branch line from Cheltenham to Orangeville in an "M" format layout in N Scale.
  11. Matthyro
    Matthyro Will always be re-membered
    Checking with my N scale ruler then 3/4 inch = 10 nscale feet. I use this as I build structures and this tells me if I am close to scale
  12. rob164
    rob164 Member
    thanks! i just made the mountain for my n scale island!
  13. Guy_narenek
    Guy_narenek New Member
    Unit Conversion's -- I cheat
    Axistek has an application for these types of calculations
    called the
    " Unit Conversion Tool v.1.53 "
    sample it, and see if it is useful for you.
  14. rob164
    rob164 Member
    cool thanks!
