my rc helicopter problem?
Discussion in 'RC Aircraft & Watercraft' started by wonderwall, May 20, 2007.
  1. wonderwall
    wonderwall New Member
    mr rc helicopter will not go right and when it goes left it spins. i've fiddled with the trim but it only makes a little change. what should i do?little polerstyrine plastic prepelori straintend the bit at the back.but i got it for my birthday
  2. terry m
    terry m New Member
    What chopper do you have ??
  3. Krashenstein
    Krashenstein New Member
    Did you manualy adjust the tail servo?
  4. Jif L
    Jif L New Member
    The pilot is completely off his face.
  5. Dan the Man
    Dan the Man New Member
    take it to the shop you briught it from and see if they can fix it
  6. Jdp2035
    Jdp2035 New Member
    are you sure its an RC helicopter
  7. Bad_Scorpion
    Bad_Scorpion Member
    if you are running with a seperate tail rotor motor then possibly the motor is bad or bad wiring to it. had a pinch in one of my wires and it would get enough juice to compensate. Just an idea.
