My new layout
3phase
104
Jacksonville, Florida
www.suprhost.com
belg said:
3 phase I was just thinking the same thing as Val about working tolerances and I guess as long as you are working with only small cars everything should be fine. The reason I was thinking problem was the very tight radius into the turn on the right lower section, its just one of those things that will become a problem with larger pass. cars and larger engines. If you could make it slightly smoother it might be closer to scale as well. Just my 2C's I wish I could get on my work table like you but at 350 and 6' 6" thats not happening. Pat
I built a similar workbench to rebuild transmitions, engined, and rear ends on,,,,,,,
