My N Layout v.2
Discussion in 'N / Z Scale Model Trains' started by pooka2hot4u, Jan 15, 2007.
  1. pooka2hot4u
    pooka2hot4u Member
    Ok here we go. My last layout attemt didnt get far since I decided i didnt really like the plan , but now I put together another trackplan which I think is alot better.
    Heres some info organized pretty much the same way as last time.
    Name: Still Undecided
    Scale: N
    Size: 3' x 6'
    Track: Atlas code 80 with remote turnouts
    Curves: Minimum 9.75" Mostly 11" and some 19"
    Power: MRC Tech 4 Model 260
    Motive Power: Spectrum 2-8-0 Consolidation in UP colors
    Industries: Interchange, Team Track, Tool Shop, Furniture Factory
    Time Period: 1890's
    Season: Fall
    I still need to get 8 more switches since i need 10 but only have 2. But i will begin construction sometime later today and try to build as much as i can with the limited number of switches i will have. Im going out today to buy some rolling stock, switches and any other things i may need.
    Now for questions:
    1. I ran my 2-8-0 around a circle of 11" track and it seemed to fit it well and i just put it down on a 9.75" curve. But just in case, will my loco have any trouble on those curves. I dont plan on going any bigger than 40' with my rolling stock.
    2. How should i wire this thing, specifically the area around the turntable? The different colors of track on the plan show my electrical blocks but any advice/fixes will help.
    Well thats it for now. Any advice you gus have will be greatly appreciated.
    And now im off to go buy rolling stock and other supplies.:D
  2. pooka2hot4u
    pooka2hot4u Member
    oh christ you gotta be kidding me!!!! :curse::curse::curse:
    once again change of plans (literally)
    i realized that the whole "giant layout under your bed" is a stupid idea. it will end up breaking from being moved around all the time and i cant even pull it out all the way out from under the bed, even if i leave myself no room to walk around.
    so for now ignore this thread too. i will get back to the drawing board and sketch up a new plan :rolleyes: which will basically be a big shelf running around the walls of my room.
    so as not to waste your time i will post any plans and ideas in the track planning section. ONCE i get a plan that i am 100% positive i will build and only after i get started on it will i make a thread here.
    sorry guys.:oops:
  3. Triplex
    Triplex Active Member
    Consolidations will handle 9.75" fine.
