My layout Progress
wickman
546
Ontario canada
47b5cc33b3127cce96446e0cb75d00000016108AZNmTds5Yua
Well I thought it's about time I post some pics of my layout seeing as alot of u guys have been a great help
then came the benchwork
47b5d631b3127cce932fcd26c85300000016108AZNmTds5Yua
plan printed 1:1 in xtrack
47b5d727b3127cce945d5fecaf5700000016108AZNmTds5Yua
WS risers glued down
47b5d727b3127cce945d5fd4af6f00000016108AZNmTds5Yua
yes you can see I had to tweak the plan a bit as can be expected
testing the radius and lining up track for turnouts
47b5d727b3127cce945d5d4c2ec600000016108AZNmTds5Yua
47b5d727b3127cce945d5d4daff700000016108AZNmTds5Yua
47b5d727b3127cce945d5d142e9e00000016108AZNmTds5Yua
47b5d727b3127cce945d5d4faff500000016108AZNmTds5Yua
time to do some cookie cutting .......its not alot shamus but it is cookie cutting LOL
47b5d727b3127cce945d5d3daf8700000016108AZNmTds5Yua
47b5d727b3127cce945d5d1a2e9000000016108AZNmTds5Yua
[can roughly see where bridges will go over gorge
47b5d727b3127cce945d5d31af8b00000016108AZNmTds5Yua
so next step is to finish supports for cookie cutter declines or inclines depending on how you look at it
well I couldn't quite decide how to go about setting up for track and roadbed so I'm going to do it the long tedious method by laying the track on the track plan layout and tracing the track. I'm sure there are easier ways but for me I have to make sure all curves are smooth and well I guess I'm just finicky. I'll lay all the track then using the blue marker outline take centre of that and line it up with centre split on cork.
47b5d726b3127cce94592523362000000016108AZNmTds5Yua
47b5d726b3127cce94592517361400000016108AZNmTds5Yua
started working on the yrd and yes tracks aren't perfectly straight
Don't forget this is just to get track roughly layed to apply cork roadbed then I'll relay track nicey nicey.
47b5d729b3127cce944742f8395200000016108AZNmTds5Yua
I got inclines supported rather ruff looking but it will al be sceneried in anyway
47b5d737b3127cce94696758a7e100000016108AZNmTds5Yua
47b5d737b3127cce9469675b26d200000016108AZNmTds5Yua
47b5d737b3127cce9469674f26c600000016108AZNmTds5Yua
I painted cork roadbed as you can see and started tacking yrd back in place for the paint I just got some brown and cut it with water 50/50 to thin it down
47b5d737b3127cce9469674126c800000016108AZNmTds5Yua
I just about got all of the double main down took a bit longer than I anticipated.
I used same bond fast white glue for fastening track and roadbed down to the styro WS risers . Couple more flex on the main and I can move onto the spurs.
47b5d739b3127cce941104e0f0c700000016108AZNmTds5Yua
47b5d739b3127cce941104d6f0f100000016108AZNmTds5Yua
finally got around to making cutout for mounth of the gorge
47b5d739b3127cce941104d571c200000016108AZNmTds5Yua
Well here the final block setup for the layout for those of use who have an appreciation for many blocks and many options for running multiple trains
Quote
And a guide line for explanation . This guy really knows his stuff.
This may look complicated at first look, but for only 24 blocks, it gives a much more flexible use of the sidings by clever use of both Blocks and turnouts to isolate two sections of track behind many turnouts. Study it carefully, and follow the “Power” along the tracks to the blue track breaks, and you should see which Feed supplies which lines and what can be isolated
1 = Power Feed to TT
2 = Inner Track Block Feed
3 = Outer Track Block Feed
4 = Inner Track Block Feed
5 = Outer Track Block Feed
6 = Inner Track Block Feed
7 = Outer Track Block Feed
8 = Inner Track Block Feed
9 = Outer Track Block Feed
10 = Inner Track Feed
11 = Yard Block Feed
12 = Yard Block Feed
13 = Yard Block Feed
14 = Yard Block Feed
15 = Yard Block Feed
16 = Yard Block Feed
17 to 24 = Inner Yard and Sidings.
Notes
Unless the 5 sidings around the Turn Table receive power from the table when it lines up, they will also need block switches and power feeds.
Main Yard is split into 2 areas, Area A and B by track breaks. Area A is fed by the inner or outer line Feeds 2 & 3. By use of Block switches 11 to 16 and the turnouts leading into Area A, two locomotives can be held and Isolated on one yard track – One in area A and the other in Area B. In area A, the turnouts will need to isolate the track as they turn against one direction. This will mean that one track will remain live. The only way to isolate both ends of all the yard
tracks is with more blocks, switches and power feeds.
Power feed 17 supplies the power leading up to the Turn Table. Power supply 19 supplies area L leading towards feed 17 so two locos can be stopped on this track or the track leading to feed 18.
Feed 18 supplies area I, and also into area J.
Area K has power feeds 20 & 21 so two locos can be stopped in the J & K area tracks.
Feed 19 supplies area C tracks up to break, where feed 23 supplies the other half of this loop, area D.
Feed 23 also supplies the passing loop in area F.
Feed 24 supplies area G sidings
I thought this was well worth posting just to show the vaste amount of talent we have here .
]image shack[/url]
You can see the engine house my son assembled that area of the layout is going to be a loading / unloading area for transports we have yet to assemble the over head crane gantry.
47b5ce10b3127cce954ec652e6e900000016108AZNmTds5Yua
47b5ce10b3127cce954ec65367d800000016108AZNmTds5Yua
Well time for another post tsarted filling in the gorge looks rough but you get the idea
heres my sons first try
Then we started filling in
47b5cf20b3127cce95754030927d00000016108AZNmTds5Yua
47b5cf20b3127cce9575403f134200000016108AZNmTds5Yua
47b5cf20b3127cce9575403d134000000016108AZNmTds5Yua
I know this one looks rough. I just threw a couple pieces aginst the rail banks to give an idea where we're goin with it
When all the banks are in we'll start shaping and maybe attach some rock molds
Well here's a little something we're toying with just to get a bit of elevation he he he
I threw on 11 of my heaviest cars just to test out my theory some cars loaded with wood screws even . Had a bit of a time with just the one loco but had no problem at all with the help of second loco added on LOL
47b5cf26b3127cce951d25a481e100000016108AZNmTds5Yua
47b5cf26b3127cce951d25b300c600000016108AZNmTds5Yua
47b5cf26b3127cce951d259700e200000016108AZNmTds5Yua
47b5cf26b3127cce951d259300e600000016108AZNmTds5Yua
47b5cf26b3127cce951d259881dd00000016108AZNmTds5Yua
3" at 58 inches from the start of the incline hmm what would that work out to ;D I thinks 5% grade he he
47b5cf26b3127cce951d258281c700000016108AZNmTds5Yua
Had to move the original turnout closer to the mountain and add in a new turnout for the incline
47b5cf26b3127cce951d258f00fa00000016108AZNmTds5Yua
47b5cf26b3127cce951d3a73c1a100000016108AZNmTds5Yua
I'm installing the risers for the new incline
Well as promised her's some pics with the new incline permanently in place
Time to start on the bridges ...hmm all 7 of them . Guess I also should get started on building up the scenery bases
47b5cf34b3127cce9521076fb84f00000016108AZNmTds5Yua
47b5cf34b3127cce9521076c397c00000016108AZNmTds5Yua
47b5cf34b3127cce9521076a397a00000016108AZNmTds5Yua
oh ya don't mind the mess haven't really cleaned up since making the new incline
thought I'd try my hand at some scenery. Used 1x4 first stilts then cardboard interlaced with a styrene wall on 2 corners
47b5cc26b3127cce95a6766e34be00000016108AZNmTds5Yua
Yep thats who it is all right my sons Cat in the Hat
47b5cc26b3127cce95a6765a348a00000016108AZNmTds5Yua
This is after first coat of plaster of paris I dipped bug screen into the p o p first
47b5cc26b3127cce95a67659b5b900000016108AZNmTds5Yua
This is after second coat done this mornin
47b5cc26b3127cce95a6764e349e00000016108AZNmTds5Yua
Thought I'd better put this one in 2 seeing as this area is on hold untill I do some scenery and seeing as it is scenery at least roughed in.As you probably already noticed I tend to bounce from one area of modeling to another which I prefer doing because as I work on an area and look over at another area I get new ideas.I'm trying different techiniques as well it took me quite a while of trial and error and practice to get the mine base painted to where I was happy and could then move on to something differenet. Plus this way I'm not rushing to get it done after all its going to take a very long time ....
47b5cc25b3127cce95b4cbfc1daa00000016108AZNmTds5Yua
Here's a few shots of the results I got playing around with the aluminum foil , got the rocks started on the top portion of the portals and a really rough start at another mountain tunnel.
47b5cc28b3127cce95a94bda037200000016108AZNmTds5Yua
47b5cc28b3127cce95a94bdb824300000016108AZNmTds5Yua
47b5cc28b3127cce95a94bcb825300000016108AZNmTds5Yua
I just grabbed bunch of 2x4's and 1x4 's that were scrap and glued and screwed them down . I cut a bunch of construction paper into strips and attached , unfortunately I ran out of time but I shuld get it covered in tonite.
47b5cc28b3127cce95a94bc9825100000016108AZNmTds5Yua
Nice mess I got going on there huh LOL
Got a second coat on the third mountain I think on this mountain I'm going to try building up the plaster and carving some strata with a knife or flat screw driver. Today when I gave the first coat a spray of water before putting the layer of plaster I thought I'd try spraying warm/hot water rather than the usual cold water to see how fast the plaster would thicken and it went hard really fast so that should come in handy where I have to layer up the steep front side.
I don't don't understand why I here so much about plaster being so messy ... it's not messy if you keep it in control I just use a big paint brush to spread additional layers and cleanup is super easy .
47b5cc31b3127cce9656680dc6ab00000016108AZNmTds5Yua
Got a start on the third tunnel mountain with a plaster covering . This time I wanted to try using the brown industrial paper towels dipped in plaster bowl and applying ... what a mess . I ended up just using my big paint brush to apply some plaster to foam board constuction then laying out the paper towels then using the brush to spread the plaster on in. I think next time I'll stick to the screen as it is more durable than paper towels although because the paper towels tore quite a bit it gave a better ending result not so smooth.
Obviously I didn't do the plaster work with the mine base in place . I fitted the base back in after plaster had hardened and found I'll have to trim the base a bit on the one side.
Anyone have some suggestions as to how to finish this hill some one with a good imagination ????.
You can see where the road will go up starting on the lower left side there will also be a road coming off top of mine base joining onto that road
I plan on having a couple mining structures on the hill all scratch built of course .First pic is the hill without the mine base in place.
47b5cc33b3127cce965bc97c973500000016108AZNmTds5Yua
Obviously this was a kinda fast track to where I'm at ...
Well it was a very busy Christmas and the rock building was very slow. I think I have about 75 lbs of plaster on the mills/rocks. Her's a few shots of my progress as you can see I'm aiming for rocky scenery once I'm comfortable that there's enough rocks jutting here and there I'll start with some painting and foilage.
47b5cc11b3127cce963aeab5d66f00000016108AZNmTds5Yua
47b5cc11b3127cce963aeabe575400000016108AZNmTds5Yua
47b5cc11b3127cce963aea97d64d00000016108AZNmTds5Yua
47b5cc11b3127cce963aea92577800000016108AZNmTds5Yua
47b5cc11b3127cce963aea90577a00000016108AZNmTds5Yua
47b5cc11b3127cce963aea8fd65500000016108AZNmTds5Yua
47b5cc11b3127cce963aeb6a171800000016108AZNmTds5Yua
And this pretty well brings you fine group of modelers upto speed as to where I'm at
here's some kinda half done pics of the mountains with ground foilage started
I took these with the flash turned off so I'm not sure if they look ok
You can also see where I gave the mine base a once over with white , I'm planning on repainting that area
47b6df27b3127cce96f24016461e00000016108AZNmTds5Yua
47b6df27b3127cce96f24010461800000016108AZNmTds5Yua
47b6df27b3127cce96f240e246ea00000016108AZNmTds5Yua
47b6df27b3127cce96f240e1c7d900000016108AZNmTds5Yua
47b6df27b3127cce96f240ebc7d300000016108AZNmTds5Yua
Oh yes and I can't forget this pic of the corner piece my 14 yr old son has been working on right from the beginning ( he didn't want this one posted ) of doing this layout he put the foam together plastered it added a couple rocks and painted it to the way it is now and is now starting to add the ground cover and trees etc
47b6df27b3127cce96f27c5c464a00000016108AZNmTds5Yua
Well here's an update on what I've been upto as you can see I've been hard at it with the plaster. I wasn't real happy with the gorge so I redid it with castings and I will soon give it a splash of paint then pour the river and complete the waterfalls. Once the inerds of the gorge is complete I will add the 5 bridges on of which will be a vehicle bridge. You can see I also have the new hill put in and I gave it a brown base coat but before doing anything more on that area I wanna get the gorge completed so I can start running the trains again .
47b6dc26b3127cce9701a5effba900000016108AZNmTds5Yua
47b6dc26b3127cce9701a5da7aac00000016108AZNmTds5Yua
47b6dc26b3127cce9701a5dbfb9d00000016108AZNmTds5Yua
47b6dc26b3127cce9701a5d87aae00000016108AZNmTds5Yua
47b6dc26b3127cce9701a5d9fb9f00000016108AZNmTds5Yua
47b6dc26b3127cce9701a5b3fbf500000016108AZNmTds5Yua
47b6dc26b3127cce9701a5b1fbf700000016108AZNmTds5Yua
47b6dc26b3127cce9701a5bbfbfd00000016108AZNmTds5Yua
Ya I know kinda messy I got caught on a messy day for pics LOL
So thats all I got for now folks I'm working on the 5 bridges that cross the gorge for now as well as looking into running a rail off the side next to the mone for a staging area decline.
wickman
546
Ontario canada
webmaster said:
The rock work is very impressive.
Is there any particular reason you used a ply riser on one side of the bridge and a polystyrene riser on the other?
Just curious..?
The reason I used a ply riser on one side and the WS risers on the other was because the side that has the ws risers is made from that cheap board thats used for dressers and stuff and I couldn't cut it and flex it the same as the plywood . The cheap board was from my sons old captains bed it supported the mattress and I figured why not use it. I like to try all the different options in this hobby so I know what works for me for the next layoout...yu'll see how I tend to try mountains in different ways etc
wickman
546
Ontario canada
I finally got the curve bridge put together to the point where I like it ... I just have to add some criss crosses across the open areas and give it a staining I already dug out under it so it fits it nice. All the other bridges for the gorge are also made up and all that needs to be done it dig out the area for bridges to sit on attach the sides and give them some staining. :)
47b6dc01b3127cce97d953a921b800000016108AZNmTds5Yua
47b6dc01b3127cce97d95397218600000016108AZNmTds5Yua
Any suggestions are much welcomed :)
Dingo69
30
Wickman,
Was just wondering what your table measurements are? The top picture is bit small to read. I have a L table are that is 3.4m * 1m & 2.5m *1m and I am still bumping around ideas of how to place the tracks.
GeorgeHO
170
Baltimore, MD
Your layout looks great. With a 5% grade helper locomotives would certainly be appropriate, and can add some operational considerations to your sessions. Do you have access to all areas of the layout? Some of your tunnel areas look to be unreachable (pun intended).
wickman
546
Ontario canada
Well guys this concludes this chapter as I'm tearing it all up and going to be starting on an around the wall layout. I found a nice place to go thru the wall for a 2' x 11' staging area in my wifes laundry room ...hope she doesn't notice. I'm searching around for new ideas for the plan my son would still like to have a double main but I think its going to be a single contiuous as well as a well spread out industrial area .So thanks for all the nice comments. :D
Gary S.
1,576
Texas
I was looking at all your photos and thinking "wow! wow! wow! great stuff!" and then read your last post about tearing it all out, are you serious???
stagingyards
34
wow you have done some fanyasic work there if I may make a suggestion I saw you had drywall joint xompound there somewhere I,m a drywall taper if you water it down just enough lay news paper over you mountain webbing it makes for good mountain coving just pour the cgc compound over the news paper a little at a time I found using cgc sheetrock 90 does the best for me gl and great pics
