My Imcold's X-wing build
bigpetr
Designer/Master Modeler
Jan 27, 2016
922
1,461
Czech Republic
Thank You, wish you can see it live, I am realy happy with it;). This test build worked OK, so I am adding it to my resource thread.
9,892
The level of detail that you are putting into this model is PHENOMENAL!!!
The time, effort, energy, and work that you are putting into this model is really shining through!!!
KEEP UP THE GREAT WORK!!!
9,549
Wow! Rhaven is right, these are awesome. Excellent! :)
9,549
Wood is unrealized paper. :)
Reactions: bigpetr
bigpetr
Jan 27, 2016
922
1,461
Czech Republic
Thank You:).
No lacquer applied. Surface is not so glossy in reality (photos makes it much more prominent). It is printed on coated silk paper for laser printing (little glossy).
At the end I will probably apply matte lacquer on some parts. Will see:)
bigpetr
Jan 27, 2016
922
1,461
Czech Republic
No problem with cracks or flake.
I use printer setting for the thickest paper, so printer bakes the toner at the highest temperature it allows. Maybe that is why it holds on the paper realy good.
Only time when it cracks was, when I cutted thin strips (details on enines for example). I solved it by making the cut few times veeery lightly. Paper strips then do not curl or twist as you cut and does not crack.
Reactions: Rhaven Blaack
9,549
Missed a couple of "Likes". You have really put these parts together with nice straight, sharp edges. Great craftsmanship. :)
