my build of Patorochs "Dreadnought MK IV"
Discussion in 'WarHammer40k' started by Sanginus, Sep 30, 2011.
  1. Sanginus
    Sanginus Member
    Hi all, hope thats my latest build is a Dread,
    want to upgrade it to venerable.
    I scratch some sections, the leg pipes are pins from cotton swabs,
    on the back i added some details and other small modifications with
    Here some impressions of construction progress,
    some weapon options to build quite complex and delicate.
    (for man with big fingers) :twisted:
    you can see, for example image 1 the bood claw parts
    The last two images shows the Dread red pre paintet
  2. arkon
    arkon Member
    superb, i was thinkin of doin that one next,i have several of his downloaded. how do you paint, do you lacquer them or ony thing else before you paint and what type of paint are you using? great work! thanks.
  3. Sanginus
    Sanginus Member
    thank you a lot,
    i use the colors of GW or water based acrylic paint.
    and i paint directly on the model !
    but I use 1mm or thickness cardboard, not paper
    I already used clear lacquer,
    only to protect it from dust
  4. arkon
    arkon Member
    thanks, keep up the great work!
  5. barad
    barad New Member
    Seeing pictures of completed dreads does tempt me somewhat :mrgreen:
    You say you used 1mm thick card, did this cause any additional problems such as folds and shaping ?
    Wondering if 0.5mm may work easier (for me at least).
  6. Sanginus
    Sanginus Member
    Hi, thanks for your note and request,
    I had no problems during assembly,
    everything could be shaped and fold well.
    It may be that it works equally well with 0.5 mm.
    I'm going to try it on occasion
