OK Herc, now I'm going to put MY 2 cents in and REALLY screw it uptooth1. i have wired my dads layout to run DCC or DC...AND, you can leave ANY locos on the layout:thumb:. its VERY EASY, just takes a few toggle switches
. FIRST,I DO believe in blocked engine tracks, even if you just had DCC engines you should have them. think about this, when you turn on DCC, EVERY DCC engine you have on the layout, the motor IS running, even if it is just sitting there!
unless an engine has QSI, QSI decoders CAN be turned off
. now think about the wear on the motor that you arent using, just sitting there running because you DON'T have it on a blocked track. ALSO, buy putting blocked tracks for engines on the layout, you can now keep DCC AND DC engines on the layout, WITHOUT TAKING THEM OFF!:thumb:. remember though, if you are running DCC, make DARN sure your toggle switches to the DC engines are OFF! AND VICE VERSA! use the same buss lines for BOTH systems, but BE DARN SURE to put a toggle switch in the positive wire BETWEEN your system and the track, FOR BOTH SYSTEMS! buy doing this, the power(current) from one system, will NOT run into the other
. i have set up the last 2 of dads layouts this way, because he has a ton of DC engines that he cant afford to convert them to DCC(retired, fixed income), and has 4 DCC engines, one with sound. Herc, you CAN run BOTH SYSTEMS, LIKE A CHARM, just NOT AT THE SAME TIME. as far as running your turnouts, that CAN BE DONE TOO. if you ARE interested in setting up your layout the way i have explained, i WILL check back on this thread tomorrow night
, if you want, i will post diagrams of just how EASY this CAN be done:thumb:
. Herc, however you wish to do your layout, i wish you the best of luck!
-Deano
