motor problems
Discussion in 'RC General & Getting Started' started by backyardbasher4life, Jul 17, 2003.
Thread Status:
  1. backyardbasher4life
    backyardbasher4life New Member
    i have a problem with my motor it is the stock .15 mach motor for the xxx-nt i wanted to see if it started...well heres the problem i can start the motor fine but when you give it a little gas it dies i figured that out its to rich and loads up but when i run the car for like 5 mins. and stop it to check if it over heats the idle lowers by like 50% then it started i am wondering if the low end is to low and and when it warms up it burns up all the gas gas in the car before entering the piston when i just need some advise so i wont ruin the motor (p.s. i put at factory settings and still dosent work)
  2. punkerboy_69
    punkerboy_69 Member
    could it be time for a new piston and sleave, or maybe just a simple glow plug?
  3. backyardbasher4life
    i found out the problem well sorta i got a motor rebuild and it works like a champ
Thread Status:
