Motor glitching problrm
Discussion in 'RC General & Getting Started' started by mastmec, Mar 3, 2004.
Thread Status:
  1. mastmec
    mastmec Member
    I'm running a Novak Tempest Pro, Reedy 11t double Sonic. Under excelleration it's glitching bad untill it reaches top end, or I let off the throttle and cruise. Slow excel. it's very slight. That's with the curent limiter turned off, when turned to about 60 to 80% it's worse. I replaced the caps. and has new brushes, trued com. timing set to 15 deg. The ESC is suposed to be no motor limit, but reading the manual it says it might be too hot a motor or needs a smaller pinion. It gives me no trouble running stock motors. Whats up?
    I'm going to try a 12t triple today if it quits raining and see what happens.
  2. mastmec
    mastmec Member
    I ran the triple and still glitched but not very much at all, tighened the slipper a little and it glitched a little more than first run. Seems to be the ESC going bad, not handling the high currents anymore.
Thread Status:
