Motor from??
4,501
Lakewood, Ca.
It is a V16 2 stroke diesel could be an EMD. It is not turbo charged because it has 4 exhaust pipes coming out the top between the valve covers. It could be a gp7 or9 or an ft-f-9, or a gp38, or an sd9. It could also be one engine out of an e-unit since they ran 2 diesel engines if I remember correctly. It could also be out of a switch sw. The problem with identifying what locomotive it came out of by a photograph is that EMD only made about 3 types of engines from 1945 until well into the 1980's. Their new ones may have given in to environmental concerns and are now 4 strokers. One of the three types of engines were put in virtually all of the locomotives from the early f-units until they switched over to the newest "clean diesels". Some would have had turbo chargers some didn't. The sd45 had a v20. Virtually all of the other EMD units had v16 prime movers.
Triplex
1,719
Calgary, Alberta, Canada
After using Winton 201-A engines in some 1930s locomotives, EMD switched to the 567 in 1939. They used those until 1965, when they switched their whole line to the 645 engine. Starting with the SD60, they switched to the 710 engine, which they still use today. The main exception to this progression are the true 6000-hp SD90s which use the H engine.
GE used the FDL engine in most power from the U25B on. The main exception were the true 6000-hp AC6000s using the HDL engine, until the ES-series introduced the Evolution engine.
16-cylinder engines are the most common for road freight engines. At any given time, a manufacturer's "standard" model will usually have 16 cylinders. However, divergence from standard is achieved in different ways. In EMD's 1965 line, the GP/SD40 had 3000 hp from 16 cylinders. The SD45 had 3600 hp from 20 cylinders, while the GP/SD38 had 2000 hp from a non-turbocharged 16-cylinder engine. GE's U30B/C also had 3000 hp from 16 cylinders. However, the U33B/C and U36B/C came later than the SD45 (though well before EMD put that much power in a 4-axle unit). They also had 16 cylinders, taking advantage of technological advancement. To get lower power for the U23B/C, GE went to 12 cylinders. Since it didn't build road diesels in the 50s and used fewer cylinders rather than normal aspiration to get lower power, I don't believe GE has ever built a non-turbocharged road engine.
Most EMD switchers used 12 cylinders; some had 8 or even 6. E-units had two 12-cylinder engines.
