modules
MasonJar
It's not rocket surgery
Oct 31, 2002
5,362
Ottawa, Canada
Related to the hotrak group is this page:
http://www.railwaybob.com/Modules/MRIndex.htm
by railway bob, who sometimes posts here at The Gauge. He has laid out a really nice, comprehensive how-to on module construction, including two options for legs.
Now what he shows is the "standard" module, with all the specs to make it interoperable with other modules. If what you want to do is make a "modular" home layout so that it can be moved easily at some future date, but not necessarily operate with others, you can make "sectional" benchwork. This would simplify your wiring, etc, but still make it easy to move (once or twice).
Sectional benchwork does not have to conform to any particular standard. THe idea is just to make it simple enought to "break" into manageable pieces if you ever want to move.
Andrew
belg
861
New Jersey USA
Thanks for the input guys, what Andrew describes in the second half of his post is what I'm looking to do. How do sections like these get joined together and how does the track get laid differently then in a regular layout? Those are the types of things I'm looking for.
Pat
60103
Pooh Bah
Mar 25, 2002
4,754
Brampton, Ontario, Canada
Pat:
How different from "regular" will depend a bit on how much moving you plan to do. If it's a show layout that will be travelling every month or so, you need to hold things down more thoroughly than if you're just going to move it when you change houses.
Sections can be joined with anything from C clamps to bolts to pattern makers dowells.
The track joints can be lift-out track sections, butt-ends with sliding railjoiners, or rail soldered to flathead screws at the table edge.
shamus
Registered Member
Dec 17, 2000
3,489
UK
There are two ways to join modules together for the track. One is to solder brass screws under the ends of the rails so the two modules butt together, and the other is to have a small piece of track (4") which fits over the join in the modules. I used the latter myself.
Shamus
F
Fred_M
I use a 9" tracks to join my modules together. I usually make the joints the middle of a road and use atlas 9" rerailers as grade Xings. That way the ballast isn't missed and the joints seem less noticable (to me). FRED
jon-monon
4,590
Cobblers Knob, IN
www.2guyzandsumtrains.com
Food for thot :)
Pat
Even if you don't want it to operate with other folks modules, you might consider designing it so some or all of them are "standard" as far as entering/exiting track is concerned. By "standard", I mean your standard or one that is already developed. My reasoning is that if you move to a different size/shape layout room, it might be nice to add/remove/replace/relocate some modules to fit. Of course, you woulkd be in for major surgery as far as scenery goes. You could, on the other hand, always build an adpting module to do what needs to be done at the time of the move.
F
Fred_M
Re: Food for thot :)
I agree with that. All my modules are interchangable (well almost) and it also allows me to rearrange my layout occasionally as well as replace and build new modules easily. It's so much easier to build a 30" by 8 ' module low in the shop with no train trafic than it is to build it in a working layout enviroment. Some call this a domino layout. Anyway I like it and reccomend it. FRED
belg
861
New Jersey USA
Fred, I really like your suggestion about using the rerailer as a grade crossing, I would love to see this close up do you perhaps any pictures? I tried to go to your homepage but got an error message is it still active or did you change the addy?
Gents there is some real good info in what you've given me and will certainly take some of these things into consideration.
Anyone have a close up shot of how these things are joined together could you please post it? I NEEED a visual reference Thanks Pat.
MasonJar
Oct 31, 2002
5,362
Ottawa, Canada
For the best (or one of the best) ways to connect true modules together, see the link I gave you to railway bob's web site (above).
For connecting sectional benchwork (i.e. your own modules that don't connect anywhere else), pick whatever seems easiest to you. I would imagine some sort of bolt or screw between each section.
As far as making joints in the rail, I would not bother. I would just lay the track as if it was a permanent layout. When it comes time to move, just take a dremel to the track.
NOTE: The reason Shamus suggested the brass screws under the track is to provide a place to solder the rails at the edge of the section. That way, you can be sure that they don't move at all. You could do this, but without cutting the track. Cut it when you move.
Andrew
Ray Marinaccio
1,940
Dewey Az.
I don't know if this will be of any help, but this shows the joint of the yard section of my HO layout.
I have a 1x4 screwed to the main section on the right to support the yard section until the two 1/4" bolts are installed.
Ray Marinaccio
1,940
Dewey Az.
This is the joint with the 2" foam and sectional track that bridges the seam.
I have a turnout over this seam and would recommend avoiding doing that if possible.
F
Fred_M
Sorry about the link not working, I just posted it yesterday and fat fingered it. It has been corrected and works now.:eek:ops: http://www.trainweb.org/zmtshortline/
Here's a picture. The background ones use the screw method. FRED
