kite platforms
Next came the kite platforms (I can only assume that these box-kite-like structures are a type of diving plane). These were an interesting piece of work. First, the platform support beams were too short; I extended these with scrap paper -- if you look closely, you might spot the color mismatch.
Next, the platforms themselves. Curiously, the starboard platform is a single solid piece, while the port platform consists of two spaced pieces. I don't know why the original was built this way, but it made for a teensy problem for the kites. The kites are designed to be built as a five-sided box, with the vanes added inside as five separate pieces. This is fine for the starboard kite, as it sits on the solid platform, and it is impossible to tell that the kite is boxed in on the bottom side and not an open structure. But since the port kite sits on two separate supports, the kit itself must necessarily be see-through. So I had to cut apart the box part of the kite, removing the 'back panel' and making a single part into four separate parts (oi!! what a headache!), resulting in nine parts that must be first rolled into half-pipes and then glued into an open-frame structure. :cry: The finished kite is a little lopsided...but at least it can be seen through!
The finished platforms incorporate the aft splinter shields and include a hoist on the port side of the superstructure.
Regards,
