I was also wondering what people use to make the roads for a scale model?
Roads - like you drive on? Depends on what kind - concrete, asphalt, gravel, dirt - but there's a lot of ways to model each.
Or do you mean the roadbed - the raised surface that the tracks are on. In that case, you can get it molded onto the tracks (see below), or you can buy roadbed made from cork or foam, among other materials, for not much $$.
I seen some kits that have different types of track which ones are best. I seen some that had a gray in color base under the track is this kind of track ok? I t was like a molded plastic. I think the scale was HO and N. I seen some track also that really looked like a real track. It was O scale.
You can get 1) track with the base (aka the roadbed) molded in, 2) rigid curved and straight sections without the molded-in roadbed and 3) track that is flexible and can be shaped to any size curve you want. There's advantages to each - cost, ease of use, realism, etc.
About what size of frame would I need for the scales listed: N? O? HO?
By frame do you mean layout surface, ie the table top or whatever? O takes the most room, N the least, but it depends on how much track you plan to put on it, how large of curves you will use, and about a million other things.
Is there anything I really need to look for when I buy my model? I plan on going to buy one Saturday.
I'm sure you are chomping at the bit to get
something as soon as you can - that's understandable, but my advice is to do some more planning first. Figure out where you're going to put it and how much room you have, then from that what scale would be best.
