Red Bull? Ha! Only I, can give you Wings .....
As I had already printed the model on 120 gsm and 160 gsm paper, I decided to make the wing membranes from the lighter weight paper.
Like the human arm, the dragon arm contains the same basic elements: Shoulder, upper arm, elbow, lower arm and then the hand including the fingers. The thumb would be represented as the long claw at the top-middle of the wing where the fingers radiate from, (the palm.)
The big difference is the membranes between the dragons fingers. Which of course, are the main components that make up the wings.
This pic from
http://www.dragoart.com shows the definitions clearly...
Anyway, I wanted to use 120 gsm for the fingers and membranes and then change to 160 gsm for the palm and the upper and lower arm. The reason for this is structural strength.
As the wing membranes of the model are made of two parts that join in the middle of the membrane, I did not want to use tabs to join these. I did not want to take the risk of having 'tab shadows' in the membrane after the glue had dried. So, I decided to remove the connecting tabs and join the membranes together using sticky labels on the back side, ensuring the joins were as tight as possible. The joins were edge coloured to match the pattern, as best as possible, using water colour pencils. The labels I use are very high tack and have an extremely long 'stick life.' I therefore did not use any glue for the joining of the membranes. This helped keeping the join a bit cleaner.
Once the whole wing is complete, I will do any touch-ups required to blend the join as best as possible.
It all clicked at this point: I have to build FOUR wings.......
Each wing is composed of the front and the back sub-assemblies, reversed imaged and basically laminated together.
I have to say, that this project has caused me to do a crash course in Pepakura.
It has taken more time to build this model in my head and working out the build order of each sub-assembly, in relation to its connecting assembly, which directly relates to the shape and structure of each related assembly and sub-assembly that connects to it, which of course affects the general structure and shape of the model as a whole, which has an indirect effect on the structure of the base and subsequent means of attachment to this base, than actually doing any building...... But, once you have worked it all out, you need to then decide which is the first piece of the puzzle........
hamr
I'll get there ..... With a bit of time, if I can find time, that is....
See you soon...
