Metal / Aluminum rulers
Discussion in 'Tools of the Trade' started by Card_noob, Apr 9, 2009.
  1. Card_noob
    Card_noob New Member
    After hitting 3 different stores today I couldn't find a metal ruler that did NOT have a rather thick cork underside (which made for quite a gap between the surface and the actual ruler edge). I saw a couple which I liked but they were made of aluminum and I wondered if, aluminum being so much softer than metal, if they would be prone to getting nicked by a blade...
  2. David H
    David H Member
    I have both steel and aluminium. The aluminium ruler has an inset steel edge on one side. Some times I use the ally side and yes it gets nicked. Keep looking for steel!
  3. lairdre
    lairdre Member
    When using my ruler with cork on the underside I score with the cork side up.
  4. Padre
    Padre Guest
    I have on with cork and one that I scraped the cork off.
  5. Stev0
    Stev0 Active Member
    I do this too. If I want to measure... *flip*. =)
  6. CK Styles
    CK Styles Senior Member
    You likely dont have a Menards there but may have some other type of home improvement store, but they sell their store branded ruler (TOOL SHOP) which is a 12" metal rule with no cork, very strong. It's perfect and only cosst a buck.
  7. SCEtoAux
    SCEtoAux Member
    The Helix Non-Slip ruler I use is aluminum with a channel down the length that helps keep your fingers away from the blade. It also has two recessed rubber strips on the bottom side that helps keep it from slipping. It does get nicked sometimes, but in the many years that I have been using it that has not been a big problem.
  8. Bowdenja
    Bowdenja Active Member
    There is another one like the one Doug posted that Gil told me about. It has a ridge handle where Doug's has a slot. Gil told me about it after I sliced the very tip off my finger using a flat ruller:eek:
    I ALWAYS use it now.
  9. Jim Nunn
    Jim Nunn Member
    This type of ruler is generally called a “machinist rule” you can usually get them at a good ACE hardware store or Home Depot for a dollar or two. I have even seen them in the Sears tool department.
    Get one that has both metric and imperial dimensions
    Jim Nunn
      File size:
      13.3 KB
  10. doctormax
    doctormax Member
    a dollar for a steel rule, once again it is Rip off Republic, you won't believe how much they look for a six inch one in some shops in Ireland. ok i will tell you. 4.99 euro. I would not pay that amount so i just bought a cheap set of stainless steel knives and the handles came off easy as i expected. ok cannot measure but i have a good ruler not metal when i need to measure. when i need to cut i use the stainless steel knives straight edge. Perfect saves me all that money.
  11. papastumpy
    papastumpy Member, one of the best sources for tools of the trade. Have purchased two, one 12" and one 6" surgical steel cut (SS) rules w/handle to keep put. Also has a large assortment of SS rulers for all taste. Check them out and you will be pleased, however the tools are not cheap, but they are not cheap made either, in fact, most will last a life time!:wave:
  12. silveroxide
    silveroxide Well-Known Member
    If measuring is not important and all you need to do is score or cut, use a metal strip. Here in the US, you can go to any Lowes or home depot, Buy the metal strips at the sheet metal aisle and with a jig saw,using the metal cutting blade cut the lengths that you need. They come in different size gauges.:wave::wave::wave:
  13. KCStephens
    KCStephens Member
  14. ltla9000311
    ltla9000311 Member
    I bought mine at the dreaded Wal-Mart for $2.49.It's steel with no cork on it either.
  15. Groovin_fusion
    Groovin_fusion New Member
    For those rulers that have the cork or some other non-slip material on the back side, here's an easy way to get the sticky crap off after you have removed the material....It's called Avon's Skin-So-Soft......It also keeps skeeters off ya. My girlfriend told about this one day when I approached here sheepishly asking how to get the stickey stuff
  16. smelter273
    smelter273 New Member
    I really hate aluminum rulers. They get nicked really easily.
  17. kirkhere
    kirkhere New Member
    If you use a rotary cutter, make sure to find a ruler that protects your fingers!
    First time I tried it without, I found it too easy to roll up over the edge of my ruler and head for my fingers. Scared me. I bought a ruler with a raised edge and a steel insert, so I wouldn't cut into the aluminum.
    Not thrilled with the cork backing, which I removed. But I love that my fingers are out of the way now.
