meta, again
Discussion in 'Gallery & Designs' started by sandu, Apr 7, 2007.
  1. sandu
    sandu Inactive Member
    Two questions about Metasequoia:
    1. Can I trim a part at the intersection with another part(fuselage where the wing gets inserted, for example)?
    2. UV mapping? How in the name of all paper planes in the world can I do that?
  2. NOBI
    NOBI Active Member
    trim part must use "boolean" plugin what availlable in full version and I think there is a good tutorial about uv mapping in metaseq around here, please seek for that tutorial :)
  3. sandu
    Thanks for the advice, NOBI. I'l look for the tutorial. Good to hear from You.
  4. sjsquirrel
    sjsquirrel Member
    Meta and UV
    What version of Meta are you using? UV mapping is only available in the registered version, and must be 2.4 and above.
  5. NOBI
    NOBI Active Member
    I use 2.3.3 registered version but I think you can use UV mapping in 2.3.3 without registered too
  6. Lex
    Lex Dollmaker
    The unregistered version only supports planar/cylindrical/spherical mapping, custom UV mappings aren't supported
