Messerschmitt Libelle
Discussion in 'Kit Reviews' started by rkelterer, Mar 14, 2005.
  1. Bowdenja
    Bowdenja Active Member
    OK............ I gotta ask about the tail.
    How in the heck did you get that glued up without any seam?
    Is it one piece?
    Great job by the way! I really like this model.
  2. rkelterer
    rkelterer Member
    the tail is one part. i formed the shape of the tail boom with thin paper around a sanded toothpick. this core part i used to form the part into a cone. then i opend the cone a little bit and filled id with UHU(yellow). now a short break for a few seconds to let the surface of the glue to dry. i inserted the core into the cone - the glue came out of the part, but no panik - with a gentle move of my fingertips i removed the surmounting glue. the first try (sorry no picture for documentation) was successfull 8)
    i will try to make some macro/macro picture of the tail :D
  3. Joseph
    Joseph Member
    About the tail: unlike Raimund, I added a small strip of paper/glueing tab from the inside. A lot of PVA glue, and I pressed the tab from the inside with a toothpick.
    Btw, everybody dislikes PVA glue - I find it great! It has no color, you can easily remove the excess (with fingertip or with a piece of card). And it is great when the fit is not perfect: put a lot of glue and the part turns to 'papier mache', so that you can 'fill' the seams.
    Raimund, are you planning to make a clear canopy?
  4. rkelterer
    rkelterer Member
    yes - i did some tests with forming celluloid :roll: - but i think the problem is to have a stable mold :? - until then the canopy is totally transparent :lol:
  5. rkelterer
    rkelterer Member
    after several attempts to vacuform a cockpit i decided to finish the paperwork first
  6. rkelterer
    rkelterer Member
    and an overview from down under :lol: (further photos not possible for today - because the batteries were empty again - perhaps i should buy a digital camera which is not so hungry :oops: )
  7. Leif Oh
    Leif Oh Member
    Very nice job on the bends in the landing gear as well! - L.
    GEEDUBBYA Active Member
    Howdy Guys,
    Reading the post about the canopy being clear and test forming it, I was taken back to some remedies I have used in the past when working with clear plastic.
    As we all know, CA or cyno acrylate glue will "fog" clear plastic really fast, so will testors "dull coat" spray on matte finish (used for knocking off glares and toning down gloss enamal).
    One way to repair this fogging, or even scratches in clear plastic is to use a very small amount of clear enamal fingernail polish over the affected area. BUT...... not all plastic is the same, so test it on a small area of scrap clear plastic first, once it dries, the plastic should be just as clear as it can be, although, in some cases I have noticed it will give a "magnifying" quality to the plastic.
    I dont know if this will help with the libelle, but it is a neat and useful tip to know. Clear nail polish is also great for making realistic looking landing and navigation lights. paint the light the proper color on the model
    first and then once dry, cover with clear polish to give it a "lens" adding depth to the light. You will be amazed at the results. Another tip is to use the wire from bread tie twist for antenna, and monofiliment fishing line painted black or colored with a black marker for guy wires. You can apply the heat of a cig from a distance of a few inches to tighten the monofiliment once the glue has set it in place. ( the fishing line shrinks in heat, thereby tightening).
    GREG aka GW
  9. Leif Oh
    Leif Oh Member
    Heating the monofilament fish line was a good tip, got to remember that! - L.
  10. rkelterer
    rkelterer Member
    now on hold until the canopy is molded (and the wheels 8) )...
  11. barry
    barry Active Member
    looks superb
  12. DHL
    DHL Member
    wonderful model !!
  13. DHL
    DHL Member
    I just bought it !
