message to Surfduke
Discussion in 'Space & Aeronautics' started by Bionic Modeler, Mar 8, 2008.
  1. I wanted to start a thread to show our appreciation for your contribution to this artform. I for one have several of your designs proudly displayed on my desk. You have friends here and not just a buch of people waiting for your next "FREE" design. We miss your posts and hope to see you back when the time is right for you.
    Thank you :)
    Anyone else want to chime in?
  2. George B
    George B Senior Member
    Heck yeah! I second that!!
  3. gpw
    gpw Member
    I second that too!!
    I had a lot of fun to follow your threads and to build some of your wonderful designs. The ASTP is doubtlessly the most impressive model in my collection. Hope to hear from you. :yep:
  4. wedge
    wedge Member
    I´m rookie in card modeling , but when I was starting with this hobby , the only one model that I wanted was your apollo :) I have a lot of models now , but I have build only three of them... When I will be good enough for your models , I will make them all - that is going to be the best day in my modeler career balloon6
  5. Nando
    Nando Designer Extraordinaire
    I hope to see You here again, and I'd like to see more designs from You.
    ... and I promise That I'll complete Your beautiful Apollo CM :rolleyes:
    :thumb: Nando
  6. paulhbell
    paulhbell Guest
    Nice build GPW. I've not buillt a 'surfduke' model yet, although I've downloaded some of them, I must get time to build one.
  7. Hans Christian
    Hans Christian Active Member
    This guy is one of the few people here that should be given at least healthy recognition for his muesum like works! bounce7
  8. dhanners
    dhanners Member
    Yeah, I haven't heard from Carl in quite awhile, either. I hope he's ok. I know his life and work can get busy, so I hope he's off making jillions of dollars so he can retire early and devote his time to designing and building great card models.
    Here are some photos of my build-up of his Apollo CSM. I modeled Apollo 7, since Carl and I were both big fans of Wally Schirra. I used different types of metallic paper, including a cool lined paper I found that, when cut to the right shapes, seemed to match the Kapton strips on the exterior of the CM.
    I also included a photo of the High-Gain Antenna that I built, using fine mesh that I found on a paint filter that I bought at the hardware store. Of course I got the thing built and installed on the model, only to discover later that Apollo 7 didn't carry the HGA. So I had to carefully remove it.
    Apollo 7 also didn't have the docking tunnel ring, so that made it easier to model in that regard. At some point, I'd like to do an Apollo 11 CSM so I can use the HGA, plus super-detail the docking probe.
  9. CArl should really be impressed with this fine piece of work. How did you achieve the metalic look so perfectly?
  10. londonbluemisty
    londonbluemisty Wayne P
    Where are you CARL???
    One of Surfduke's last entrys was dated 10/15/07:
    "I am back, (and ready to party,(LOL))! I have moved,had a computer crash,Family problems,New Plant Start-up problems, etc......."
    Then Nothing!!!!
    Come on Home:wave:
    I miss waiting patiently for you to release one of your Fantastic Designs...
    ( Surfduke's Mercury-Atlas 1/96)
      File size:
      40.6 KB
  11. dhanners
    dhanners Member
    Thanks for the kind words, Tim. I got the metallic look by using metallic paper. I used at least three different kinds. The paper on the CM is what's known as a "cast coated text" paper, and it is made by Wyndstone and the particular name of this paper is "aluminum lines."
    For the SM, I used another type of silver paper, but I can't recall the name or manufacturer offhand. I found it at an art-supply store. The paper comes in several colors, including some metallics like silver, gold, copper and a dark color. I used some of the gold paper for the rear section of the SM, where the SPS nozzle attaches.
    There's more about the model here:
    Starship Modeler: Gallery (Real Space)
    (You might note that in the model in the photos there, the RCS nozzles are gold. I "toned" them down with a silver Sharpie to make them look more silverish-gold, if that's a color....)
  12. Bengt F
    Bengt F Active Member
    A Beautiful Tribute to Carl´s Model Designs
    That is a BEAUTIFUL Apollo 7 CM! You´ve got outward-bulging the frames of the windows just right and the Kapton Mylar tape pattern is simply mind-blowing - that fine lined silver paper sure does the trick in this scale.
    I am still struggling away, half-way through the enlarged version of the CM - I have made a pattern for the silver Mylar tape strips and I am thinking about using thin strips of duct tape, or wider bands of the same, although embossed to achieve the line pattern.
    Slowly getting there . . .
    Thanks for sharing those fine photos, David
    and thanks a million, Carl, for all your fine scale models!
    All the best from Stockholm,
    Bengt :thumb:
  13. jparenti
    jparenti Member
    Carl, you've done an awesome job with your models. Finally, I have an Apollo CSM and Skylab that I can take apart and peer inside at all the little details. :mrgreen: I can't thank you enough for that. I hope that when you return, you'll see how much the community appreciates you. Good luck!
  14. Lex
    Lex Dollmaker
    Mind Lex barging in... but may I ask what happened to Surfduke?
  15. dhanners
    dhanners Member
    I think the issue is none of us knows what happened to Carl. He seems to have dropped off the face of the card modeling Earth. He was a frequent contributor, and it seemed like he was adding new models to his site every 15 minutes, and then.... Nothing. Nary a peep.
    Prior to that, I'd e-mailed back and forth with him and even spoke with him on the phone a couple of times, and I can attest he is a good, solid chap and I'm inclined to believe he's probably just off working hard somewhere, or is taking a breather from the hobby, which we all could use from time to time.
    The thing is, none of us knows, so there's really no reason to speculate. I just know he does great work, and his efforts have contributed greatly to our genre of the hobby.
  16. mvink
    mvink Member
    I heartily agree with DHanners. I was working with Carl, doing the instruction sets for all his projects when, in the middle of all of it, he stopped communicating with me. I tried calling and emailing him but nothing, nada, zip. Unfortunately, I am on the west coast of the U.S. and Carl lives on the east coast, so I can't just pop in on him (and I wouldn't, unannounced anyway, Carl), but I really do miss him, his work and his wit.
  17. Mechanic
    Mechanic Member
    I've been meaning to do this since timhinds1@cox started this thread, an open invitation to all who have made, or even just started a Surfduke project, to post a picture of what they made,
    finished or not.
    As popular as GPW's images are, there must be a lot of people that are working on his models, why not show what an impact Surfduke has has to our community?
    Here's mine, an experiment with some metallic papers I found.
    (bear with me if this doesn't work, first try at adding an image here)
  18. George B
    That looks awesome!!!...I'll have to try that paper.
  19. Bengt F
    Metallic Paper Apollo CM
    Incredible, Mechanic,
    That really looks like heavy, polished metal! What kind of metallic or silver paper is that? Any brand name or suggestion on a retailer?
    All the best,
    Bengt :thumb:
  20. Mechanic
    Mechanic Member
    The chrome paper I don't know the brand (I tossed the wrap a while back) but I purchased it at an Xpedex store. The heatshield paper is a dull silver (perfect for the SM) that I literally found at my wife's office, I don't have any info on it, they've had an old ream for years.
    I've almost abandoned the chrome paper, though. I'm having trouble trying to add details, in that nothing will adhere to the foil side, and things like glue tabs show thru the reflectivity(?) of the foil. I tried a little embossing but it didn't work out very well. Like you, I'm thinking about using some sort of tape, or adhesive backed foil.
