Mechwarrior 4 Mechs
Discussion in 'Science Fiction & Fantasy' started by shiftdel, Oct 30, 2007.
  1. shiftdel
    shiftdel Member
    K'jev, MK II is on my future plans, however it will took some time to get ready, as I already have several models in the works right now...
  2. shiftdel
    shiftdel Member
    Good news, after an eternity I was finally able to find a design solution for the split of Mauler's torso parts.
    It was so amazing simple, that it is so embarrasing that I couldn't figure it out before wall1
    Now I will unfold it on Pepakura. Anyone interested in beta test it for me?
  3. Gomidefilho
    Gomidefilho Member
    Yes Shift I'm ready!!! hehehehehehe!
  4. shiftdel
    shiftdel Member
    Thanks Gomide, as soon I finish unfolding it I will send the model for you :)
  5. shiftdel
    shiftdel Member
    Bad news about my Novacat build: the knee joint is badly designed, as the unfolding of it, and turned to be a pain to build...
    I just changed it, the fix was easy, but the bad part is that I will need to redo the tedious unfold process in Pepakura, ehich will delay a bit releasing the model... :(
  6. armorbimbo
    armorbimbo Member
    Do what I do. Remove that piece from the current pdo page/s and then make a new pdo with just that piece. That way you don't have to redo the whole model...
  7. shiftdel
    shiftdel Member
    I would do that if it wasn't just a tiny little small piece :) I think would be a waste of good cardstock just to print it...
    Anyway, maybe I could use the extra effort of redoing the PDO to correct some small fitting problems, that I was going to live with, just to avoid redoing the PDO :cry:
  8. shiftdel
    shiftdel Member
    After a while without building anything, I'm posting some of my recent progress on beta building my Novacat.
    This is the torso, it went together reasonally well, some small fitting problems, nothing that I can't live with, so it will remais the way it is now (I bought and built plastic kits with a much worse fitting then my Novacat, so...)
  9. shiftdel
    shiftdel Member
    The right guns mount, I really like the way that one ended up:
  10. shiftdel
    shiftdel Member
    Now a "family" pic, all parts put together... well, in fact these are not all parts, I still have 18 parts left to build...
    You can see the shoulders subassemblies, the head, some bits here and there, as well as the upper and lower legs.
    The lower leg is one piece part, although it is a bit hard to build, the part ended up quite strong.
    The upper leg has 3 parts, but I already changed it, separating the lower part, which is hard to build and makes that point weak.
  11. Millenniumfalsehood
    Back when I played Mechassault I'd eat Mad Cats for breakfast with my Nova Cat. :twisted:
    I can't wait till you finish your beta build, Shiftdel! :mrgreen:
  12. OhioMike
    OhioMike Member
    Anybody manage to download Blackhawk?
  13. blaar
    blaar Member
    I only started out but would also help with the test build if you need some more people to help with the Mauler.
  14. shiftdel
    shiftdel Member
    Curently I hape 3 people working on it, one of them already started his building, so I don't really need another beta tester, although another one wouldn't hurt at all ;)
    The most important thing that I need from a beta tester is feedback on how the build is going so I can correct any errors.
  15. Gomidefilho
    Gomidefilho Member
    My Mauler Beta Build
    Well friends!
    After a long period I began my test of assembly of Mauler, it is certainly one of largest Mechs that built already, he is in the scale 1/40 exactly with 30,6 cm of height, the "kit" has 13 pages, however making a detailed exam thought the model is simpler than Vulture that had built previously.
    I began for the chest, the assembly of the sub components that form that piece were made without profits, the pieces bend very well, just tends to have some care with the parts that it forms the front and the rear of the chest...
    Nexts steps!
    Head and Missiles Pods...
  16. CJTK1701
    CJTK1701 Banned
    It's coming together very nicely, looking forward to your updates.:mrgreen:
  17. shiftdel
    shiftdel Member
    Great build Gomidefilho!!!! As always ;)
    I was worried about the fitting of the torso parts, but your build showed that is not a concern anymore :D
    Thanks again for beta built it for me
  18. Gomidefilho
    Gomidefilho Member
    Hello Shiftdel!
    It is being a pleasure to build that model. As soon as has more news I post here... :thumb:
  19. JCM_Kerinsky
    JCM_Kerinsky New Member
    Hi all
    Looking forward to getting my grubby hands on the new models your doing Shiftdel.
    oh and incase any ones intrested in table top gaming im doing a mech based game a little like battle tech but with a bit more balance and less dieing in the first turn! if you wanna know more ASK!
  20. shiftdel
    shiftdel Member
    Another small update, Novacat sexy legs :D
