Yes, I have the steam boiler feed water pump is not installedVery interesting. Total water loss, no water recovery, no condenser, right?
YesOpen
I'm no mechanical engineer, but is that a boiler coupled with a two-piston engine? Could you please elaborate a little more on that? Just out of curiosity, because I have lived "on top" of boilers almost my whole life as a line officer, but I was more into Ops.
And I can't figure out the size... I think the long pipe we see in your pics should be about 10cm (4'), is that right?
As you can see, we want as much information as you would like to offer. Blueprints would be really neat, if you have any.
No, I use a motor to drive the water pump, steam engine can also output drives the water pump.Are you running the electric motor as a generator?
