Marek TA-183
Discussion in 'Aircraft & Aviation' started by Nothing, Jan 25, 2008.
  1. Nothing
    Nothing Longtime Member
    i found thie little gem the other day and had to start it, despite having a another big project going. It has 8 pages of parts, and 2 instructional diagrams. i started withe cockpit.not complicated but looks pretty decent.
  2. Nothing
    did a spot of frame work. i added some fishing weights(the black objects) as it will have a nose high configuration when done.
    NULLMOON Member
    I have this little plane its one of mareks best kits :thumb:
  4. eric_son
    eric_son Member
    Marek has that?
    How come I didn't see it in DeWayne's site?
  5. Nothing
    i got it from paper international. so far things are just going great with this kit. got the gear bays and the centerline ordanance bay done.
  6. eric_son
    eric_son Member
    Found it! Thanks for the heads up.
    I frequently visit the SPI site...but somehow, I didn't notice the Huckebein in their offerings. I'll be sure to get that when I get back home next week.
  7. Nothing
    got a little more done. im taking my time as i really whant this to turn out right.
    this is the intake.ilike the textures used on it.
    there is an inner and outer skin to this.
  8. lriera
    lriera Member
    You are a multitask man. Two buils, two posts.
    I like the way you work.
  9. newcomer
    newcomer Member
    any idea where i might buy one of these ?
  10. Nothing
  11. Nothing
    started far the only problems have been my own and they were very minor.
  12. Nothing
    more skin. the nose is a little tricky still working on that.
  13. Nothing
    ive found one puzzeling sorta problem. the kit has really good internal support.
    except for the blue stripe. there is no support here to tie in the rear.the tail has a lot of support and the front. but nothing between the two.
  14. eric_son
    eric_son Member
    Very nice! I also like the abundant fuselage for the missing ones you've just mentioned.
    Anyway, I have a question. (See attached image)
    I noticed that there are some glue tab placeholder patterns on the fuselage former.
    Is that part of the model's design?
  15. Nothing
    no. i use scrap or discarded cardstock to laminate the formers, instead of wasting good stock.
    i think he my have left that spot open as when i tested the rear formers to the fuselage it actually feels to be pretty sturdy.
  16. eric_son
    eric_son Member
    Hehehe... I thought that at first.
    But then I noticed that the pattern was centered squarely in the former. That's why I thought it was a placemarker for glue tabs. :D
  17. Nothing
    well, this tail is a little more complicated than i thought it would be.some of the skin overlaps eachother. the exhaust part has no means of supprt so ittle have to be attached to the skin.
    thw support problen i mentioned earlier ,turns out that area is solid.
  18. Nothing
    i figured out that i made a mistake on the rear. i said the top and bottom skins overlap. they dont. the back 3 bottom strips are to be formed into rings then the uppers mated to them. to late for me to fix the one i did. the instructions werent real clear on this point. ill show what i mean later on.
  19. Nothing
    heres the "elbow" joint. it gets glued to a tab peice.
    and this is the rear. these are the rings i mentioned.
    and this get attached to the rear.
  20. Nothing
    heres the exhaust attached.the fit was not real good because of the overlap peice i did wrong.
    and then the 2 fuselage fillers.
    and the vertical stabilizer
    now its back to resolve the nose.
