Making the little people stay put
Richard Gude
25
I am having an open house and even though my railroad is yet un-ballasted and needs a few more buildings, I would like to set out a few people. Problem is they won't stand alone and I am not yet ready to totally commit to their final positions. Do you use a little rubber cement on their feet? The additional problem is that I don't want to damage the area that I place them in as I can't re-paint many of these areas. What do you recommend?
Thanks, rhg
Doc Holliday
613
Big Valley, California
Try earthquake wax or putty. It is used to secure items, such as pottery, to shelves. It's available at a bunch of stores, Walmart, K-mart, Target, maybe Home Depot, drug stores, some grocery stores, etc. Works great and is easily removeable without residue.
Doc
Jac's Lines
152
Rochester, NY
Some of the older books suggest using beeswax (pull the figure across the wax so a bit sticks to the feet, then place on the layout). I've used this for short term placement for photos, and residue hasn't been a problem. I imagine it could be if you really smear the beeswax into a deeply textured surface (like deeply grained wood) or if you put it on a surface that will be repainted in the future. I've also used the WS product that David mentions, and it works well.
oleirish
37
Central Point,oregon
I take the stands off the little people and then mske sure there feet are square,then a little drop of Vaseline on the feet It works for me,Look at the little people in this photo
JIM
green_elite_cab
Keep It Moving!
Apr 4, 2005
1,876
Hainesport NJ
you know what i think? they should make a magnetic figures (magnetic feet atleast), and a clear, flat paint or something that has metal in it that you can paint where you want people. that way, the magnets will hold the feet down to the layout, and you can move them.
kchronister
353
Boiling Springs, PA
I'm not sure how they could make a clear paint that had metal in it - metal not doing well on the transparency front...
Another suggestion is magician's wax. like the other waxes mentioned, it's sticky and leaves no residue. I mention it only because I know that, whatever the actual substance, it's designed specifically to adhere and hold well with just a pin-point size dot. Any real-world or online magic store should stock it.
MasonJar
It's not rocket surgery
Oct 31, 2002
5,362
Ottawa, Canada
If you have a foam base for your layout, you could cut the base (if any) off the figure, drill a small hole in the foot/leg, and insert a short piece of wire or a pin (minus the head). Then you can put the figure where you wnat, and only a tiny hole is left if you move them.
Andrew
