Makin' History!
Vic
1,699
Columbus GA
Another Record Coming Up
I think there is another record coming up too....Charlie is about to hit the 1,000 mark on the number of posts. Should we start a "pool" as to when it will happen???:D :D :D
rockislandmike
1,257
Edmonton AB
dayfornight.qazam.com
Nope, no way I can control that. But it's the same in my job - I make a best estimate forecast, and my employer's final results should be pretty close. If one department all of a sudden stops purchasing stationery or educational materials, then yep, it screws up my forecast. But that's not very likely. Nor do I think it's very likely any of the three of you will vary that significantly from the numbers I used - you might try to post a lot more, or not at all, but eventually you will tend towards your average.
I do update my forecasts on a regular basis, to allow for more recent information. I.e., in this case, I might revise my forecast at the end of the month.
shamus
Registered Member
Dec 17, 2000
3,489
UK
Michael, can you forecast the lottery numbers for this Saturday please, love to be able to buy a brass Climax.
Shamus
