Mainline Coaling Tower
Discussion in 'Scratchin' & Bashin'' started by Matthyro, Jul 9, 2004.
  1. Matthyro
    Matthyro Will always be re-membered
    An article appered in the November 1990 model railroader about converting a kit.
    I decided I could use a couple of these so am scratchbuilding two with my faviourite material, cardboard
    The first phot shows beams cut from corrugated cardboard. They are 1/8th of an inch.
    OOPS sorry my error. It was in Railroad Model Craftsman mag
      File size:
      50.9 KB
  2. Matthyro
    Then I cut 1/8th strips of paper and glued them on the open sides of the corrugated cardboard to make the beams.
      File size:
      55.1 KB
  3. Matthyro
    Here are some of the cerealboard shapes
    More to come later
      File size:
      32.4 KB
  4. pomperaugrr
    pomperaugrr Member
    Wow Robin, you are off and running once again! The bridge project was wonderful, now the coaling towers. You have convinced me to try your material of choice when I start building structures for my next layout. I can't wait to follow the progress on this project!
    Thanks for sharing your efforts with us!
  5. Fred_M
    Fred_M Guest
    Good project! Fred
  6. Matthyro
    Thanks guys. Eric I am sure you will get a lot of pleasure working with cardboard
  7. TrainClown
    TrainClown Member
    Cardstock is my building material of choice too. ;) I like to see your posts and pick up a few tips. Good to see your onto another project.
    One thing I was wondering. When you stick the 1/8 paper strips to the 1/8 cardboard, exactly how do you do it to get it so clean, straight and wrinkle free? In other words, how are you handleing your glue? (white glue I assume) And, do you use a variety of glues in the building of your structures. Do you ever use hot glue or 5 min epoxy?
    TrainClown :)
  8. Will_annand
    Will_annand Active Member
    Here goes the master again. Can't wait until to see this one. You always amaze me Robin.
  9. Wyomingite
    Wyomingite Member
    Hi Robin,
    Well I see your at it again. Sure can't wait to see your progress.
    Ron :thumb: :thumb:
  10. Matthyro
    Thanks for the encouragement folks.
    TC I use white glue for 98% of what I do. Some epoxy where needed. No other kinds than glue sticks to glue background pictures to masonite.
    All I do is spread a bead of white glue down the length of the corrugated strip and smooth it with my finger. It helps to have a damp cloth available to get the glue off before I lift the paper strip up. I place the strip at one end of the beam and let it settle on to the rest of it. I then smooth the paper with my finger and thats it.
    I have also glued 1/8th strips of paper on the cerealboard cut outs. I use a piece of corrugated card to reinforce the corners when I glue sections together as seen here.
      File size:
      42.6 KB
  11. Matthyro
    The first legs added to the main structure and the engine house starts to take shape
      File size:
      42 KB
  12. Matthyro
    The engine house added to the main structure
      File size:
      34.8 KB
  13. Fred_M
    Fred_M Guest
    That's looking nice, and it's so small. You are amazing. Fred
  14. Matthyro
    Thanks Fred. It stands 5 7/8ths inch tall
    I got some more done last night while watchin a doubler header of Canadian Football League games. The ones between Montreal and Ottawa, Montreal won, and the one between Edmonton and B.C. Edmonton was winning when I went to bed at the begining of the fourth quarter. Getting too late for me. But I did add more leges and structural beams as can be seen here.
      File size:
      35.4 KB
  15. Lighthorseman
    Lighthorseman Active Member
    Just What I'm Needing!
    Robin, I'll openly grovel for any plans you might have for this structure. I'm looking for exactly (pretty sure...) what you're building here, to use as a smallish engine coaling facility on my line. Everything I seem to find is designed for huse locos, or huge numbers of locos. I'm just wanting to service one at a time, lined up beside a water tower.
    I'll be watching this thread with rapt attention. :thumb:
  16. RailRon
    RailRon Active Member
    Robin, I'm so glad that you finished another box of cereals and transform the remains into something very useful! :D :D :D
    In earnest - coaling towers are fascinating structures, and I am following the making of your model with great attention. And it looks like this will be one more masterpiece in your tradition. :cool: :cool: :cool:
    Thank you for sharing!
  17. Matthyro
  18. Chessie6459
    Chessie6459 Gauge Oldtimer
    looks good :thumb: :thumb:
  19. Iron Goat
    Iron Goat Member
    The coaling tower is looking great.... you've got me looking for a November 1990 back issue of M.R.. I can't wait to see more....
  20. Matthyro
    I really goofed folks. The article was in the Railroad Model Craftsman mag. Not MR as I stated earlier. My apologies
