Hi Everyone
This is not a new project.
Actually i started to work on it in 2008 and put it aside ever since (was it really that long? I'm getting old )
Since i never bothered to share it with anyone but a few close friends, i'll try to crate a overview of the progress so far.
The main idea was to figure out, how the APC could actually be constructed with the interior layout as seen in the movie. We all know that the interior used for filming set was too large to actually fit inside the dimensions of the full size Prop, but the general layout resembled the general Footprint of the APC's interior volume.
The Layout i came up with is this:
Seems like i had the same ideas about the general arrangement as the guy who came up with the awesome blueprints published at hydride-ion
Therefore i was convinced, that with some tweaking here and there a fitting interior could be desingned.
The other part of motivation was to try my skill at creating a papercraft while also providing myself with a model that could to go with my 28mm / Warhammer 40k style models.
The only papercraft availiable at that time was the one by Jan Rückr wich is a good papercraft but unfortunately based on a 3D model wich was quite inaccurate in a lot of aspects (side slopes, rear wheel arches...) - and without any interior.
So i started off with the APC schematics from the Colonial Marines Technical Manual, scaled them to 1in48 added my own ideas:
I wanted the wheels, doors and turrets to be poseable.
After some days of work i had my first rough kit layout finished and did a first test build.
Of course there were some issues with it and i continued to update some of the most problematic design flaws and buildt a second prototype:
So i called it a success regarding the general layout of the kit although there are still some minor issues.
I continued to fiddle with the files i created from time to time but my motivation was obvoisly insufficient to put in all the work required to solve all the remaining problems.
When i found this forum, the interst grew a again and after some rummaging in the chaos i call storage, i was able to dust off the old test builds:
Especially all those fiddly bits on the interior and the turrets are not exactly finished and some adjustment has to be done to some of the slopes etc.
Most problematic: the textures are really bad - back then I did my design work in MS Paint (!) and I'm still lacking the skill and the patience to redo it in better quality.
My goal is to fix some of the known issues and build another model with documentation of the process.
If anyone is interested, i'll gladly share the files i created.
(especially, if someone is among you, who feels able to create better textures...)
