This is one part of Micromodels/Modelcraft set B1 British Fighting Ships. It is the MTB 102.
The kit did not come with the mast, flags, railing, radio box or hardware, I made them.
I drew the mast template as accurate as I could using reference photo's. I printed it then laminated two more pieces of cardstock onto the mast template then cut it out. The rigging was straight before I put the flags on...??? The flags I cut directly from a reference photo.
I used tiny straight pins for hardware, I cut the round off both sides of the pin head to resemble cleats...or whatever you call 'em.
I found a pic of the sky on Google, and the Ocean I found here...SOMEWHERE. I printed the Ocean on plain paper, then crumpled it into a little ball, then unfolded it 95%, sprayed with a clear gloss. I used the computer to airbrush the wake, but that is all. More pics next post.
