Discussion in 'Getting Started' started by jimbogibbo, May 7, 2007.
  1. jimbogibbo
    jimbogibbo Member
    what is a good lubricant for the gears and joints on my trains?:???:
  2. MasonJar
    Labelle makes a good line of plastic friendly lubricants - grease and oil in various weights.
    Use grease on gears, and light or medium oil (assuming HO scale) for everything else - bearings, siderods (steamers only ;)), etc.
  3. Gil Finn
    Gil Finn Active Member
    How is vasoline of plastic and 3 in one oil. I have always used what was at hand. Am I doing harm to my HO engines?
  4. MasonJar
    While those are good lubricants for their respective uses, I think the primary problem with them for models is that they are too thick. The engine will have to work harder simply to move, leading to early wear, and shorter life. And I am not entirely sure that vasoline is plastic-compatible... On metal gears, it probably doesn't do any harm, but there are definitely better things out there. Sewing machine oil is a good substitute, as it is a very light oil. Clipper oil is probably ok too. "Bunker C" oil is right out...! ;) :D
