Looking for a pepakura G36C model
Discussion in 'Dream Kits & Wish Lists' started by Jobi101, Jan 30, 2008.
  1. Jobi101
    Jobi101 New Member
    Basically wondering whether anyone knows where i can get a G36C pepakura model.
    In case someone doesn't know what the G36C is.
    HKPRO:  The G36C Compact
  2. Lex
    Lex Dollmaker
    Um... Actually it's not like you find a random object and hope it's in paper...... But I suppose there must be one somewhere, any helps?
  3. Stev0
    Stev0 Active Member
    If you can find one in 3DS you could spend the time on it to break it down into the pieces you need. Try looking at sketchup models. If you have the new Pepakura, sketchup files will work in it as well. Sketchup will be your best bet.
    Edit. Voila ... G36 - Google 3D Warehouse Search
  4. Stev0
    Stev0 Active Member
    Ugh... I dont have Pepakura 2 so I just noticed it is not Sketchup but Google Earth models that the program supports.
  5. Jobi101
    Jobi101 New Member
    You can export to google earth. Most of the G36Cs that are the right shape are too complex. For some reason i can't edit them in sketchup.
  6. Stev0
    Stev0 Active Member
    Well ... if you want the right shape then complex is the only way to go.
