Looking for a bright idea
Discussion in 'N / Z Scale Model Trains' started by jmurphy148, Feb 1, 2008.
  1. jmurphy148
    jmurphy148 Member
    I'm building a new layout approximately 38x85 inches. The talbe top will be covered by 1" foam. The layout was designed in WinRail. I have printed it out full scale on 45 sheets of paper which I have accurately taped together. I have the full size printout lying on top of the foam and now my question is "How do I transfer the tracklines from the paper to the foam"?
    Any bright ideas out there?
  2. who_dat73
    who_dat73 Member
    You could use a pin and go along poking lil holes all along wher its gonna go or easer go to Wally world and in the sewing dept they should have a small pizza cutter type thing that will do the same thing but you just roll it along!!
    Or put carbon paper under the pages and pencil over the lines!
  3. mummert
    mummert Member
    I would second the idea of the little pizza cutter looking thing. The ones I have seen look like a pizza cutter with small points on them. That would make a good impression on your foam. Another cheaper idea would be to trace with a pen and apply a little bit extra pressure that would transfer it as well. If you have a hard time seeing the impression possible going over the impression with some chalk may highlight the impression. Never tried this though. Hope this helps
  4. TrainNut
    TrainNut Ditat Deus
    I tried the carbon paper idea. It worked about as well as a lead baloon. I did however, do the same as you in printing out my whole layout on 8.5 by 11's. I then placed that over the top of the foam and at short intervals, I poked a whole through the paper and into the foam with a pencil. I then removed the paper and connected the dots. If you could find one of those pizza thingies, that sounds a lot easier. Just make sure your paper is attached to the foam or when you start rolling the pizza cutter around, the paper is going to move.
  5. MSBoxer
    MSBoxer New Member
    I simply used a wooden skewer we had left over from kabobs and poked a holes every quarter inch or so. The skewers also work well holding multiple layer of foam together until the glue sets, or stirring paints, or making holes for trees, or....
  6. Squidbait
    If you don't mind a mirror-image track plan, photocopies or laser-printed pages will transfer their image with heat. Lay the page printed-side down, and run a hot iron over the back - voila! Instant transfer!
    Other than that, the pounce-wheel suggestion is probably the best, if you don't want the paper there. I just glued the paper down, and laid my roadbed right over it.
  7. mcbane666
    mcbane666 Member
    Get your self a glue stick(or a few) and glue the pages to the table, then just cut everything out after that isn't track, lay the road bed on top of the paper that is still glued to the table
