Logon's run pistol
Discussion in 'Science Fiction & Fantasy' started by movieman, Feb 3, 2010.
  1. movieman
    movieman Member
    I have just uploaded a 1:1 scale papercraft logans' run pistol which you can download once it has been cleared. I have pictures, but due to this forum restrictions of 15 posts before you are able to add links to the pictures you will all have to wait, but the model is well worth looking at, I will also upload some other models I have done including a classic cylon rifle, logan's run tracker and a model of the classic spaceship from the 80's series Blakes 7.... the liberator.
    all the best steve
  2. movieman
    movieman Member
    Logan's run Follower
    I have now just added to the download section, the follower device used by the sandmen to track runners, this will only be available once it has been cleared.
  3. Elliott
    Elliott Senior Member
    Approved. :thumb:
    You may want to consider making these available in PDF format as well. Your models will be available to a wider audience as many people don't, or can't, keep up with the latest PDO viewer release. :)
  4. movieman
    movieman Member
    Thanx for the advice, will do Pdf versions as well in future :)
  5. movieman
    movieman Member
    Sandman SD gun
    Here is a picture of a completed sandman SD gun that I did last year.
  6. vulcan8630
    vulcan8630 Member
    Hey, this looks good....Interesting, I was dabbling in design and this was my next project...I noticed some paper modelers use wood putty, spackling, or "super glue" to laminate, stiffen and smoothen their paper models did you use any of these techniques on your model?
  7. movieman
    movieman Member
    No I use fibreglass resin or I mix up some fibreglass mud (FM) whist is a 50/50 mix of fibreglass resin and car body filler, think it is called bondo in the USA... and P38 over in the UK, you simple brush it on and it set smooth, any floors can be sanded out..... proves to be very strong finish, though with big items and armour I back that with fibreglass tissue, which is easier to use and you get a smoother finish than the heavy duty fibreglass strands, 2 layers of tissue is stronger that vaccum form plastic and about the same weight.
  8. vulcan8630
    vulcan8630 Member
    Thank you for sharing that bit of information...I would like some of the paper models I attempt to not look like paper!
  9. strangelysaucy
    strangelysaucy New Member
    looks awesome! lovely piece of retro design!
  10. mangler525
    mangler525 New Member
    not bad, i loved that movie.
  11. movieman
    movieman Member
    I have uploaded a re-model of the logan's run sandman's deep sleep gun in to the download section, once approved you can download it.
  12. Tintellaar
    Tintellaar Member
    Ice robot
    Anyone ever try to do the ice robot 'Box' in papercraft? That would be a cool add...
