Lockheed F-22 Raptor flyable paper model
Discussion in 'Aircraft & Aviation' started by chaiwat kosatanakom, Dec 22, 2012.
  1. chaiwat kosatanakom
    chaiwat kosatanakom New Member
    It takes years to achieve this project and we spent hundred of models before successfully found the secret how this model can truely fly. With the request from a Lockheed Martin officer, who wished to see this aircraft flight character if the Raptor become the paper model then the invention emerged.
    We found that this airplane flied as if a tiny paper plane when it was airborne three years ago.
    Today... this project again on development for being a future paper airplane model for global interested person.
    Let make this toy become the public hobby for people around the world! :wave:
  2. Famous Dave
    Famous Dave Member
    OOO. I'm interested. Looks great. Fabulous color and build. Thanks for sharing.
  3. micahrogers
    micahrogers Active Member
    Ok I need this one too.
  4. shika
    shika Member
    P' Chaiwat (Brother Chaiwat)
    This is really great krub (Sir).
  5. Zathros
    Zathros Guest
    I find this model incredible, I look forward to your new one. It's hard to imagine how much better you can make this but I totally believe you!! :)
  6. freddyman
    freddyman newbie
    amazing looking flying model. i can't wait until this model becomes available
  7. Famous Dave
    Famous Dave Member
    @ Chiawat. Thank you for the gift.
  8. freddyman
    freddyman newbie
    jack, you done it again. thanks for the model
  9. Zathros
    Zathros Guest
    That sounds excellent. It is wonderful to see all the support equipment around these craft.
    I think many people would be amazed to see the ground support needed. Having models of this stuff is great, as the same equipment is used on many aircraft.
    Merry Christmas and may you have a Happy New Year to you Chaitwat. :)
  10. Tecumseh
    Tecumseh New Member
    Happy new year and thanks for your contribution.
  11. P_Luna
    P_Luna New Member
    That looks fantastic! An upscale of this look like it would make a great RC parkjet, either with an EDF or a pusher prop...
    Thanks for contributing this wonderful model!
  12. shika
    shika Member
    Dear P' Chaiwat,
    How do you plan to control? Radio? Wireless?
    Shika ^ ^
  13. chaiwat kosatanakom
    Today, it still being the free ride without any control due to it is on invention process. sign1
  14. P_Luna
    P_Luna New Member
    That sounds amazing! Made of paper? Do you have the plans for that? I'd love to build something like that! The servos, batteries, radio controls, etc. are so small these days that it wouldn't be difficult to install those and make it fully controllable!
  15. chaiwat kosatanakom
    I was suggested by the real aviator (S-2 Tracker, and the Nomad) to invent this tiny paper models to be flyable. We once success to make it glide as a wonderful glider. We failed to make the RC duct fan because the engine is too big to fit in the tiny paper. We made the ordinary RC flying F-86 and the Nomad. It flied but its structure were not strong enough for the wind when it flied fast.
    Now, we are working to use the micro scale computer fan with micro batteries. It will take some time but we hope it will be an amazing one in the future.
    You can download my old version of Raptor in the download page, provided by Zathros. :p
  16. Zathros
    Zathros Guest
    I have no doubt you will succeed. A lot of people just put in the tiny clear pusher props and they fly so great, and the prop is virtually invisible. It is a viable option. :)
  17. Zathros
    Zathros Guest
    If you put the motor in the airframe, and use a long shat for the propeller, use a small rubber hose on each end of the shaft to absorb the vibrations and it will work. he harmonic imbalance can cause the motor to run with much less power output.. You could also use the spring from a Ink Pen, it will do the same thing. These can be glued in place with crazy glue. Just make sure you have a "Flat" on the motor shaft so it will not slip. Using this method will allow you to have more flexibility with the center of gravity. The picture below is a picture of what is used in "N" scale trains. The coupling is flexible and absorbs unwanted vibrations and oscillations from the motor spinning and feedback from the propeller are absorbed (in this case). A small rubber hose would serve the same purpose, just make sure it's tight but flexible. This parts are extremely small. I believe the parts are approximately .125" on an inch, or 3.175 mm. I made a little picture to try and explain. There would have to be a bearing on the end of the prop and the motor being securely mounted would not need a bearing as the motor has one in it already. :)
  18. chaiwat kosatanakom
    Dear Zathros,
    Thank you for your kind recommendation.
    We will try the other method, which soon we hope it will be success.
    Just finish a new Isreali Kfir C2 a few hours ago and hope to postit for your viewing rinight.
    I am working on the Sikorsky MH-65 Blackfoot or the Stealth Blackhawk that fallen during the Bin Laden air raid.
  19. Zathros
    Zathros Guest
    Chaiwat, your popping these models out so fast, it's hard to keep up with you!! Thank You for you contribution to the this community and the community at large. You are an inspiration. :)
