listen to this!!
Discussion in 'RC General & Getting Started' started by 69stang, Mar 23, 2005.
  1. 69stang
    69stang Guest
    i was runing my b-max going about 40mph and all of a suden my rear tire locks up and my front two tires balloon out of controll!!!it was awsome. i broke my rear(stock)axle because of all of the touque in my truck!! now i need to bye hardened steel cvds (they come in a pack of two and are like 60 bucks if you have a highly modified e-max i sigest them)
  2. SpArKeY_STi
    SpArKeY_STi Guest
    Whats really fun, is when you get it fixed, jack it up real high, then soften the suspension. Take it slow, make a sharp right (or left) then throttle it, if done correctly (with pratice) one side should lift off the ground, then balloon up and screech. Fun, and annoys neighbors if its gas on top of all the other noise.
  3. rcdrifter
    rcdrifter Guest
    You gotta get us some pics of this...
  4. 69stang
    69stang Guest
  5. 69stang
    69stang Guest
    try the links again now they should work. tell me if u like
  6. SpArKeY_STi
    SpArKeY_STi Guest
    aww, i wanted more carnage...
  7. 69stang
    69stang Guest
    il take a pic of the axle when its out
