Lippisch P.13a (Luft46)
rbeach84
New to Paper
Feb 5, 2010
33
5
Norfolk, Virginia [USA]
Unzipping
Hi David,
I just did a test download from Zealot and I can open the Zip without problems.
I used 7-zip to make the archive, but I tested it on Windows' native ZIP explorer.
I can email you an uncompressed (PDO) version of the file directly if you like?
Eric
Eric, I think the issue is the way the archive is compressed, it is not compatible with the WinZIP because it is 'double-compressed'. When I open it using Total Commander, it displayes it as an archive within an archive, something I have noticed with several folks' compressed files, including some RAR instances.
Which Windows are you using? The XP Pro I have does *not* unzip it properly, so I can see David's problem (this is probably a 'backwards compatible' issue within Windows...)
Back to your design, I like it. I have IW a plastic kit of the P.13a that I have done quite a bit to with regard to detailing, including adding a complete airflow path from nozzle to exhaust. That isn't really possible with your model unless I can figure a way to 'bore out' the intake through the corrugated structure (very innovative, BTW!:thumb:) However, I can easily incorporate similar cockput detailing, and the canopy is a simple, single curvature sheet - so that is easy to incorporate also!
I was wondering, will you offer a 'no-lines' version? The 'dashed' lines seem to detract from your nice texture & camo a bit. As PNG, I assume I could edit them out using Inkscape... something I might try just as an exercise. Would you mind if I did a 'repaint' in that regard?
Thanks again for sharing, very nice work - and I bet it will 'glide' just dandy as well.:cool:
Regards, Robert
eric_son
72
4
Q.C., Philippines
gruumsh.multiply.com
Thanks for the kind words.
I originally tried to make the ramjet assembly (intake to exhaust) but the target scale (1:48) made it too finicky to assemble. :) When I develop the skills to do the internals (cockpits and gunpods), I'll definitely get back to this model and do a remake, probably in 1:32.
RE: ZIPped archive.
I used 7-zip (www.7-zip.org) to make the archive. It unpacks without problems in the native ZIP explorer of XP and Win7. But hmmm... I've got 7-zip installed on both my XP and Win7 machines. Maybe 7-zip somehow changed the default extractors on the os.
When I get home tonight, I'll re-pack using a different utility and see if I can update the files in my the download section.
RE: no lines
Ooops... sorry about that. I made an incorrect assumption that you can switch on/off the fold lines in Pepakura Viewer. I just realized now that the option is not available. I'll put up two versions of the PDO (w/ and w/o fold lines) when I get back from office tonight.
Cheers!
- Eric
eric_son
72
4
Q.C., Philippines
Sure go right ahead. I'm open to other camo schemes. I'm pretty much limited to the camo schemes I can find in my Luftwaffe resource books.
I'd also want to try out adding some weathering effects.
Indeed it does! Hahahah... When I did my alpha/beta build, I enclosed a screw big enough to fit inside the intake, and gave it a test flight. It glides surprisingly well, and pretty stable too! I was expecting it to wobble a bit but it didn't. :)
