Lippisch P.13a (Luft46)
eric_son
72
4
Q.C., Philippines
gruumsh.multiply.com
Here's my take on the Lippisch P.13a.
The design was based mainly on the 3-views I got from www.luft46.com.
I used Metaseq, Pepakura and Inkscape.
Here's how the test build looks so far (scale = 1:48 )
picture.php
picture.php
picture.php
picture.php
I'm still having trouble estimating the size for the internal formers/bulkhead. Once I get that right, I'll start adding color/camo...
Reactions: lons fede
eric_son
72
4
Q.C., Philippines
Thanks!
Anyway, I finally ironed out that nasty problem I had with the main fuselage's formers.
I tried something different but it turned out pretty well.
Here's the entire build process:
picture.php
Instead of going with the traditional formers for the fuselage, I opted for this accordion like structure. My goal is to make it act like a kind of a spring to keep the fuselage from collapsing and at the same time, make it easier to assemble the two parts of the fuselage together.
picture.php
First half assembled....
picture.php
And hey!! It works! Hahaha...
picture.php
Now to assemble the wings. Wings come with simple formers.
picture.php
No problems here. :)
picture.php
The rudder / cockpit goes next.
picture.php
Done!
picture.php
Here's how the model looks when the wings are attached to the fuselage.
Notice that there's a small portion of the wing former sticking out... I'll fix that by clipping out a small portion from the front of the wing former in my Meta / Pepakura files.
picture.php
Rudder / Cockpit attached!
picture.php
Here are the remaining parts -- the intake and the skid.
picture.php
Attach the intake first....
picture.php
The skid goes last.
I got a lot of extra details on the model after buying an e-copy of the Reichdreams Dossier #18. Fascinating stuff.
I'm off to add some camo for this now.
I'll put it up in the download section once the camo is done.
eric_son
72
4
Q.C., Philippines
All done!
Some shots:
picture.php
picture.php
picture.php
picture.php
picture.php
I thought the P13a would be incomplete without its own trolley... so I hastily whipped up this one. I tried to keep it as simple as possible to avoid fit problems.
picture.php
Some minor adjustments in the Pepakura tab sizes are in order... after that I'll put this in the downloads section.
eric_son
72
4
Q.C., Philippines
Sent to the downloads section and waiting for admin approval. :)
By the way, I can't seem to add thumbnail pictures to the model. The add picture button keeps complaining that the filename extension is invalid. I've tried JPG, BMP, GIF, PNG and even no extension. Has anybody been able to upload pictures of their stuff in the downloads section?
peter taft
878
Hi, Super design and a excellent build. Be proud of what you have achieved.. indeed be VERY proud sir :thumb: :goldcup:
eric_son
72
4
Q.C., Philippines
Hi David,
I just did a test download from Zealot and I can open the Zip without problems.
I used 7-zip to make the archive, but I tested it on Windows' native ZIP explorer.
I can email you an uncompressed (PDO) version of the file directly if you like?
Eric
