Lionel Ives armature rewinding
d_train
3
Any advice on how to accomplish this? I have an old Lionel-Ives 1661E that must have had a serious incident. The armature windings are "grounding out" to the armature stack and thus to the motor shaft. I rewound the motor and I still get the same problem, less resistance between the shaft and the windings (magnet wire) than through any winding. Is it safe to insulate between the iron armature and the winding wire?
F
Fred_M
Also, did you test the communtator for grounds before you rewound the motor? Fred
d_train
3
The commutator is fine, I checked it out. Infinite resistance from contact to contact and between each contact and the shaft. The problem is only in the windings. Where can I get insulating paper? Thanks!
