lionel is recalling the cw-80
Discussion in 'G / O / S Scale Model Trains' started by ozzy, Mar 20, 2007.
  1. ozzy
    ozzy Active Member
    was at train club last night, one of the members is a lionel dealer. he said there being recalled. but only some of them. has to have the right serial #.
  2. Cannonball
    Any idea what the serial numbers they're looking for?
  3. ozzy
    ozzy Active Member
    nope, i will have to call the shop and ask. i need to know if mines one of them.
  4. Dick Elmore
    Dick Elmore Member
    :oops: Can't remember. What does the cw-80 look like? Thanks.
    Texas Chief
  5. Cannonball
    Just like a little black box. ;)
  6. ozzy
    ozzy Active Member
    ok, on the bottom of the transformer theres a tag, at the bottom of that tag the last line says made in china, then to the right of that is a 4 digit #. if there is a "G" infront of that # yours is ok and was made after they fixed the problem. but if there is NO G then you need to take that # to your lionel dealer and they will send that number in to see if its one that is being recalled. NOT ALL TRANSFORMERS WITHOUT THE G NEEDS TO BE RECALLED. so if you dont have the G yours still could be a good one.
    lionel will replace it for free.
  7. Cannonball
    Thanks for the heads up, Oz.
    I'll have to check mine when I get home from work.
    Any idea what the recall is for?
  8. ozzy
    ozzy Active Member
    i dont know whats its for, i guess i should of asked when i
  9. rogerw
    rogerw Active Member
    Hopefull not a over heating problem or something like that ,be carefull.
  10. Cannonball
    If it is, then mine's safe.
    I accidently left mine plugged in for about 10 hours yesterday while I was at work. :oops:
    When I got home it was still on and the cooling fan was running like a wild jackrabbit but everything still worked fine this morning when I ran a few trains around the layout.
