Lionel Fastrack questions/problems
Discussion in 'G / O / S Scale Model Trains' started by Arc, Dec 8, 2007.
  1. laz57
    laz57 Member
    DR> JOHN, no problems with my 0-72 and 0-48 fast track. I had em running over a year now. Knock on wood.
  2. 60103
    Arc: A sneaky way to get an extra insulated track section is remove the tab on the bottom that joins the 2 outer rails. I think there's just one and it only requires that you loosen 2 sets of tabs. You can do this if your LHS is out of them. Or if you need a curve in the operating section.
  3. Arc
    Arc New Member
    Thanks for the tip. I figured that out and removed the tab from a 30" piece of straight track to activate the signals sooner, works great! :thumb:
