lights
L
lester perry
I usually get decoders from one shop. But a shop closer to home has started carrying DCC but he is not very knowledgeable. The first shop supplied resistor for lights the new one doesn’t. I need to know what to get for the lights to get from 12v to 1.5v , a radio shack number would be nice as I know very little about electronics,
Les
TrainNut
Ditat Deus
Sep 15, 2004
1,731
AZ
If no one else replies with an answer to your dilemma, PM Woodone. He would more than likely be able to help you with that.
Gary Pfeil
2,510
Boonton NJ
Or do what I do: I have resistor values on hand in increments of about 100 ohms, starting near 60 and up to 1100. I start at the high end and work my way down, using whatever value lights the bulb.
L
lester perry
I think I found it in doing some reading, I came up with 1 ohm. Hope this is right
Les
beamish
HO & Steam Engineer
Jan 11, 2007
154
Saskatoon,SK,Canada
1 Ohm is NOT correct. That will either fry the decoder, the light, or heat the resistor up so much you melt the loco. You should be using something like 1k(1,000) ohm 1/4 watt resistor.
woodone
367
Phoenix, AZ.
Not 1 Ohm!!!!!
1 ohm will not work-- a blown light bulb for sure. :eek:
1k (or 1000 ohm) a good place to start- I would think that 750ohm would do the trick.
The new book on DCC has a chart on resistor valuues for DCC.
woodone
367
Phoenix, AZ.
VOLTS and AMPS
To get the proper resistor for your lights you will need to know the voltage of the light and the amount of current that it draws. Most likley will be in milliamps for the current draw. Like 15MA or could be 60MA.
You could hook up a 1.5 volt battery to the bulb and hook up a multimeter inline to read the milliamps. That way you would know what kind of amps the bulb is using.
What we are doing is to use Ohm's law--R=E divided by I or I =E divided by R or E= IR
R is resistance I is current and E is volts
Hope this migh help
L
lester perry
Well I just bought some 1k ohm resistors at Radio shack. I will give them a try and let you know how it works
