lighting question
jrparish
13
visalia
:confused: Is there any way to put 2 signal lights beside the track,hook them to the switch they're beside and have one ON on the direction the switch is pionting and when you flip the switch,that side turns of and the other side will turn on?:confused:
60103
Pooh Bah
Mar 25, 2002
4,754
Brampton, Ontario, Canada
It will depend on the switches and controls you're using.
If you have basic sectional track where the switch machine is molded in as part of the switch, it's fairly difficult.
You may be able to put a microswitch beside the points if something sticks out there when the switch changes.
If you have a separate switch machine, these are available with extra contacts that can be hooked up easily.
If you have a switch that kills the power to the track not taken, you could hook lights up to the tracks, but they will vary in brightness with train speed and may not last long if you run at full speed a lot.
