Lenz / NCE D13SRP Decoder issues.
Discussion in 'DCC & Electronics' started by Kimble, Apr 2, 2007.
  1. Kimble
    Kimble New Member
    I'm a new user (less than a month) with a Lenz LV100 & LH90 throttle.
    I have a Bachmann Spectrum 2-8-0 DCC ready with an NCE D13SRP deocoder.
    I'm trying to read and then set the address to the loco's road number, but I keep on getting an Er02 error. The decoder is installed correctly (the unit moves FORWARD and the 0 function turns the headlight on and off) so I don't think that is it.
    I tried reading several other CVs and each time during a rEAd, Er02 was returned.
    I am using an isolated programming track. It's a seprate oak plank with two 9" sectional tracks. The DCC is connected with alligator clips on the end of the rails.
    Any ideas?
    Rob Carignan
    Portland, Maine USA
  2. Dansco
    Dansco Member
    I have an atlas master (which is based on a LENZ system) I think Er02 means the programmer cant comunicate with the dcc decoder. Dirty prgramming track etc.
    Hope this helps...
  3. Kimble
    Kimble New Member
    Thanks. I figured it out soon enough. I was using the power bus wires, not the programing bus wires. Basically, I didn't even have the programing track conected.
  4. nhguy
    nhguy Member
    Yup, That would do it. I was thinking it could be the alligator clips. But if your not connecting the wires then it's hard to read.
