LED lighting
Discussion in 'Tips, Tutorials & Tools' started by rmks2000, Nov 28, 2006.
  1. Bowdenja
    Bowdenja Active Member
    OK I posted this link before, but here it is again.
    If you scroll to the bottom it will draw a circuit for you if you plug in the numbers.
    They suggest 3.5 drop across and 20 mA for the LED
    Then it will calculate the resistor, and tell you to bump it up 10% and then tell you what resistor to use.
  2. Bowdenja
    Here is a screen shot for 9 volt 1 LED 3.5v drop and 20 mA
  3. Bowdenja
    Here is the screen shot, using the GURU to figure 9 volts 3 LEDs and the circuit you can build with the correct resistor to use.
  4. Bowdenja
    And just for grins........... here is a 9 volt circuit with 32 LEDs.......... no I don't want to do this but it is possible.
  5. Zathros
    Zathros Guest
    That really is one awesome link. It is amazing how much stuff is out there. That is a good one though and I have book marked it for future reference. I have also ingrained SteveM's suggestions as his model allows scaling up without much though and has built in safety redundancy.
  6. SteveM
    SteveM Member
    here is another site with lots of information about LED's and also a resistor calculator;
  7. Zathros
    Zathros Guest
    Fantastic SteveM. I always wonder where people dig up these links. I Googled LED sinfo but had not found any of these sites. Thanks a lot.
  8. rmks2000
    rmks2000 Member
    Can anyone recommend a good site to buy electonic components from?
  9. Bowdenja
  10. Ashrunner
    Ashrunner Member
    I am probably the only guy on Earth who could solder an LED to a 1.5 volt battery terminal and still get electrocuted. I'll leave all this voltage and ohmage talk to those of you who know what you're doing...hehe
