Originally posted by ezdays
It could be the electrolytic if your timer was set for longer cycles. Even if you were using a 555 (great choice for this application), we would use low-leakage capacitors if we weren't too fussy about the accuracy, but tanelum capacitors if we got over 1 or 2 mfd. Electrolytics have high leakage resistance which acts like a voltage divider in any R-C circuit preventing it from ever fully charging or fully discharging. The larger the capacitor value, the smaller the leakage resistance.
They can be bought on eBay for next to nothing - from like 15¢ apiece and up in bulk http://cgi.ebay.com/ws/eBayISAPI.dll?ViewItem&item=3802511855&category=4663Originally posted by b28_82
BTW how much do those 555 ICs run anyhow?
Try 40 cents U.S. here in single quantities. The have ordering on the web or with an 800#. They also have reasonably priced caps and other electronic parts. You can't beat their switch prices anywhere.Originally posted by jon-monon
Peanuts, at least from a good supplier. I dunno at Radio Shanty probably cheaper to use a 555.
That would help a lot. Put down values of your caps and resistors and any information you have on the LED and any transistors you're using would help too.Originally posted by b28_82
well i replaced the electrolytic caps with ceramic caps and still the same effect. I would have thought that the higher the resistance the more noticeable the flash but perhaps i thought wrong. I'll draw a schematic of what i'm using and maybe one can help me a lil.
Just a few comments on your circuit. It's been a long time since I've built an oscillator like this, but two things, your RC time constant may be a bit short, like increase the cap size to 1 mfd or the resistor to 10K and I would suggest adding a resistor to the base of each transistor to limit the base current.Originally posted by b28_82
here we go And the LEDS are 2.1v, 25mA, 6.3mcd
