Learned something today (hand laying related)
Discussion in 'Getting Started' started by jkristia, Mar 2, 2003.
  1. jkristia
    jkristia Member
    This is related to hand laying track on pc ties without rail joiners.
    This is probably well known to everyone who has done hand laid track before, and it’s pretty obvious (now) that it would happen, but at the time I laid the track I didn’t think of it.
    What I learned. On curves, never never have a join on both rails in the same place, but stagger the joins. I had a rail join on a curve, both rails in the same place, and everything was fine until today whan I started adding some ballast. What I didn’t think about when I laid the rail is that wetting the ties dissolve the glue (only while wet of course) which causes the rail to straighten out a little bit and get the join out of alignment, so, from now on I will always use staggered joins on curves.
  2. sumpter250
    Ouch! Hope you could correct the problem with a minimum amount of trouble. On the other hand.....that's one lesson you won't ever need to take again. :D :D :D
  3. MCL_RDG
    MCL_RDG Member
    And I thought i'd learn something about...
    ...bandaging a smashed thumb!
