Landing gear wire for 1/33 plane models
Discussion in 'Aircraft & Aviation' started by cardmodeler, Feb 8, 2006.
  1. cardmodeler
    cardmodeler Member
    I am trying to muddle my way through the Maly(or Maty, I'm not sure which it is) Modelartz Wildcat kit, and the Polish instructions are giving me fits. I know I need wire for the landing gear but I can't figure out what diameter the wire should be. Any help would be much appreciated. Happy modeling.
  2. Bowdenja
    Bowdenja Active Member
    I use paper clips.......... others use floral wire.
    I also have found that if you get some printer labels you can use that to wrap the wire and make a better looking strut..........:twisted:
  3. Swinger
    Swinger Member
    Use 0,8-1mm wire (in my Wildcat I used paper clips, too).
    P.S. It's neither maty nor maly, but mały. ;) Pronounced like "w" in English.
  4. shrike
    shrike Guest
    Piano wire - stiff and springy yet easily bent without breaking- is readily available at most hobby/craft shops.
    Metric Size Nominal Imperial Size
    1mm .040
    .8mm .032
    .5mm .020 /.025
    .3mm .012
    1mm = .0394 inch, but available wire sizes don't corespond exactly
    Google for guitar strings about $5.00 a set. Sizes up to .5mm, good to have around.
  6. mwangarch
    mwangarch New Member
    Piano wire is hardened and will ruin any wirecutters or pliars...just be aware that you need a dremel abrasive disc to cut through it (sparks!). Paper clips are soft wire and can be formed easily and cut with hand tools.
  7. bfam4t6
    bfam4t6 Member
    I use good old paper clips. The larger ones usually have a larger diameter, but I stick with the smallest size.
