Konrad Kujau Atlantia Base in the spirit of Revellfan
9,549
Danke, Cylongirl. Ich denke, Sie haben recht, IKEA Kopien sind die Bauhause Idee. Sie sind zu ähnlich Zufall sein.:)
Thanks Cylongfirl, I think you're right. They look too much alike to be just a coincidence.
You guys have caused me to stretched my knowledge of German, and I think I am making myself sound like an Idiot!
@Revell-Fan, that is what I believe is the proper expressions. "Pooling of thoughts" vs. "contributions", you only need say "contributions" or "for your contributions", I understood what Cylongirl was expressing. I love this kind of exchange. :)
Werkschafttinken, was an art form that was represented of those who worked in factories or with their hands and made art work from the objects around them. The picture below, to me, fits in this concept. We used to make flowers out of the curls of aluminum that cam from cutting the metal. Contrasted with bits of other metals, they were quite beautiful, though, like real flowers, their lives where short lived as nothing could leave the factory, and they ended up in the recycle bins. My German Language Teacher, who was from Germany, was a bit older, and this was in 1977, so I am pretty sure she experienced the BauHaus art movement. She taught of this art form, and it seems to be being erased in the whitewashing of history.
I believe Cylongirl is right about IKEA. I think they are totally ripping off BauHaus art form ideas, and are claiming them as their own. Their furniture falls apart after a short while, so I don't buy anymore of it. I has become too expensive.
12,349
Ah, I see! Thank you very much for the lesson (and worry about your German do not, as Master Yoda would say ;) ). :)
BTW, 1977 was a very good year. I was born three weeks before Episode IV premiered..! ;)
cylongirl
Galactica lives in Germany
Jan 3, 2015
1,198
3,396
95
North East Germany, Europa
Zuerst hatte ich den laminierten Atlantia Schriftzug ausgeschnitten.upload_2015-1-9_19-13-24.png
At first I had the laminated Atlantia lettering cut out.
Da es gut aussah erfolgte auch das O.K. von Garry, dem Zylonen.
Since it looked good was done and the O.K. Garry , the Cylons.
"By your command!"
Im nächsten Schritt habe ich die Buchstaben aufgklebt und dannach mit der Reißnadel die Linien nachgezogen.
Mein Mitarbeiter zeigt hier einmal wie es fertig aussieht.
In the next step, I have aufgklebt the letters and after that traced with the tack lines .
My staff is here again as it looks finished.
Wärend also die Buchstaben trocken kommt "Mörser Karl" ins Spiel. Hier habe ich erst einmal das laminierte Blatt ausgeschnitten.
Und, auch hier, mit der Reißnadel die Linien nachgezogen.
During car , the letters dry " mortar Karl" comes into play. Here I once cut the laminated sheet .
And here, too , with the tack traced the lines .
Den Kreis, hier habe ich mit dem Zirkel das Laminat angeritzt und anschließend mit der Schere ausgeschnitten.
The circle, here I have scratched the laminate with a compass and then cut with scissors.
Die angeritzten Kanten knickte ich über einem Stahllinieal ab.
The scratched edges I snapped off over a Steellinieal/ Steelruler
In der Folge habe ich das Ganze auf eine Pappe übertragen, welche später für Stabilität sorgen soll.
Übrigens hätte ich hier die Anweisungen von Galactican besser gelesen dann hätte ich mir das Heraustrennen des Kreises sparen können.
Doch dazu später mehr.
As a result, I transferred the whole thing on a board , which is installed to provide stability.
By the way, I had better read the instructions from here Galactican I could have saved myself the cutting out of the circle.
But more on that later .
Die selbe Prozedur (siehe oben: das Gleiche, das Selbe
) nun noch einmal auf Plastebasis.
The same procedure ( see above : the same thing, the same thing ) now again on plastic base .
Das Ganze einkleben und den mittleren Kreis raustrennen.
The whole glue and separate out the middle circle .
Kleine Unsauberheiten habe ich im dannach mit einer Feile entfernt.
Nun kann die Pappe unter die Plaste geklebt werden. Jetzt stimmt auch die Höhe mit den später zu verklebenden Seitenteilen.
Small weaknesses I have removed the dannach with a file.
Now the cardboard can be glued under the plastic . Now also agrees with the height of the later to be glued side panels.
Während dieser Arbeiten hatten die Buchstaben Zeit zu trocknen und können nun ausgeschnitten werden.
Das dann so aus.
During this work, the letters had time to dry and can now be cut .
The display as.
Am späten Nachmittag habe ich dann noch das Ganze Zinkfarben eingefärbt.
Die verschwundenen Lininen habe ich später einem mit Bleistift dann wieder sichtbar gemacht.
Dank dem vorherigen Anzeichenen mit der Reißnadel konnte ich diese gut wiederfinden.
In the late afternoon I still have inked the whole zinc colors.
The Missing Lines processing I have one then later made with pencil visible again.
Thanks to the previous Anzeichenen with the tack I was able to find this well .
Nur in einer Ecke hatte ich wohl etwas vergessen, konnte es jedoch rekonstruieren.
Only in one corner I had forgotten something , but it could be reconstructed.
Die nachfolgenden Bilder zeigen einmal den Farbunterschied.
The following pictures show once the color difference from me and Revell fan
HGJ
12,349
Very good! :) The idea with the ruler is excellent; I wouldn't have thought about this. thumbsup
EDIT: I meant "compass", not "ruler"! ;)
9,549
Cylongirl, The drawing tools you show in your posts show your talent, and the transference of idea to reality, done by hand. Very impressive. :)
Die Zeichenwerkzeuge, die Sie in Ihren Beiträgen zeigen zeigen Sie Ihr Talent, und die Übertragung der Idee bis zur Umsetzung, von Hand gemacht. Sehr beeindruckend. :)
cylongirl
Jan 3, 2015
1,198
3,396
95
So on it goes . If I now documented in some detail , this surely bore the professionals and old hands here in the forum . I'm doing but rather to those who , like me, are among the novice and do not have the opportunities or want to buy and hold tinker with the normal budget. This knowledge only as background why will be displayed here for some maybe be too trivial.
So now selected cable ties, 1cm width , and thought because of the length to cut .
Also weiter gehts. Wenn ich jetzt etwas ausführlicher dokumentiere wird diese sicherlich die Professionellen und alten Hasen hier im Forum langweilen. Mir geht es aber vielmehr um Diejenigen welche, wie ich, zu den Anfängern zählen und nicht die Möglichkeiten haben oder kaufen wollen und halt mit den normalen Haushaltsmitteln basteln. Dies Wissen nur als Hintergrund warum, wird hier für einige vieleicht als zu trivial erscheinen.
Nun also Kabelbinder ausgewählt, 1cm Breite, und wegen der Länge zum abschneiden nachgedacht.
Um die Leere unter dem Kabelbinder aufzufüllen nehme ich einen Halbrundstab aus Holz und säge 1 cm Stücken ab. Das ist die Höhe des Bauteiles bis zum Kabelbinder.
To fill the void under the cable tie I take a half round bar of wood and saw 1 cm pieces from . This is the height of the component to the cable tie.
Auch den Untergrund habe ich weiter bearbeitet.
Also the ground I have further processed
Now the whole stick to cold wood glue .
Incidentally, you can order great write his name
Next, we need a Soviet tank . A ruin is sufficient .
Davon benötigen wir die Antriebsräder.
Of these, we need the drive wheels.
Die Räder auseinander trennen und runterfeilen.
Separate and hone down the wheels apart.
Now just lie down and watch a trial basis ......
Nun mal probeweise hinlegen und anschauen......
Now people take their 4 tubes Sekundenkler from a Euro shop.
Nun nimmt man sich 4 Tuben Sekundenkler aus dem Ein Euro Shop.
Unscrew the cap .
Kappe abschrauben.
We need this small intermediate ring located there
Wir benötigen diesen kleinen Zwischenring der sich dort befindet.
Reactions: Rhaven Blaack
cylongirl
Jan 3, 2015
1,198
3,396
95
And here is the result of the whole action . The part is needed here.
Und hier das Ergebnis der ganzen Aktion. Das Teil wird hier benötigt.
Now we need a rod with smaller diameter
Jetzt benötigen wir einen Rundstab mit kleineren Durchmesser
Now 4 small pieces cut .
Jetzt 4 kleine Stücke abschneiden.
Now I cut the paper wheels unnd adjust them to the diameter of the armored wheels.
Nun schneide ich die Papierräder aus unnd passe sie an den Durchmesser der Panzerräder an.
Den mittleren aufgeborten Kreis weite ich mit einem Pinselstil und später mit einer Rundfeile.
The middle circle I placed braids wide with a brush style and later with a round file.
Again, the small rings of instant adhesives .
Auch hier wieder die kleinen Ringe von den Sekundenklebern.
Andere Baustelle selber Projekt...ankleben, rundfeilen.
Other construction project itself ... stick , round file .
Tageswerk, probelegen.
Day's work , sample set .
That's it for today /
Das wars, für heute.
HGJ
cylongirl
Jan 3, 2015
1,198
3,396
95
And now, just for who want abuen it a look/
Und jetzt für diejenigen welche es vielleicht nachbauen möchten....
Zuerst benötigte ich ein etwas größeres Überrschungsei.
First, I needed a slightly larger Ferro- Plasticegg.
A small test proves that it fits , the edge has been signed by me.
Ein kleiner Test beweist das es paßt, der Rand wurde von mir angezeichnet.
Im Anschluß daran mit einem Stück Klebeband makiert.
Subsequently, with a piece of tape makiert .
Calculate the circumference of the circle now
U = d times pi here 6cm * 3.14 = 18.84 cm
This length I wear now on a strip of sheet.
Jetzt den Umfang des Kreises berechnen
U = d mal Pi hier 6cm *3,14= 18,84 cm
Diese Länge trage ich jetzt von einem Streifen Sheet ab.
These strips bend and put a tape in the end.
Diesen Streifen biegen und am Ende einen Klebestreifen setzen.
Re:Konrad Kujau Atlantia-Base im Geiste von Darkmoonspirit und Revall Fan
« Antworten #16 am: Heute um 19:03:20 »
Zitat Ändern
@Struschie: danke-
Nun gehts weiter.
zuerst benötigte ich ein etwas größeres Überrschungsei.
cylongirl
Jan 3, 2015
1,198
3,396
95
zusammenkleben
stick together
Wärend der Ring klebt und aushärtet verklebe ich das halbe. gekürzte Überraschungsei.
During car ring sticking and cures I splicing the half . Surprise shortened .
Einen übriggebliebenen laminierten Papierstreifen nehme ich um das Überraschungsei zu fixieren.
A leftover laminated strips of paper should I use to fix the Surprise .
Ausschneiden, ausrichten, probieren.......
Cut, Align , try ......
Nun 11 Stücke a 0,5 cm mit dem Chopper abschneiden.
Now cut 11 pieces a 0.5 cm with the chopper.
Nun noch mit Holzleim die Lücken schließen.
Now just fill in the gaps with wood glue .
The middle and two opposite points determine at a curvature can be solved this challenge well with tape.
Die Mitte und zwei gegenüberliegende Punkte bestimmen, bei einer Wölbung kann man diese Herausforderung gut mit Klebeband lösen.
Prototype:
Vorbild:
Konrad Kujau
Now I have the little pieces mounted on the outer ring .
Nun habe ich die kleinen Stücke am Außenring angebracht.
Fix the keystone .
Den Schlußstein befestigen.
The longitudinal strips now produced by cross- cutting.
Jetzt die Längsstreifen durch Quertrennen hergestellt.
glued
aufgeklebt
See and be glad.
ansehen und sich freuen.
HGJ
9,888
I like how you are mixing the materials in this project to get the proper effect that you wanting.
I am looking forward to seeing how it will turn out.
