Kato locomotives different speeds
Discussion in 'N / Z Scale Model Trains' started by Inder, Sep 8, 2007.
  1. Inder
    Inder New Member
    Hello guys,
    I need your help with this problem.
    I just purchased a Kato GE AC4400CW on ebay and it's used.
    It runs great at slow and fast speeds.
    I also purchased a new Kato GE C44-9W on ebay as well.
    The problem is, I'm currently running a DC system but the locomotives run at different speeds. The C44-9W is significantly faster than the AC4400.
    I don't see anything wrong with the slower loco and it actually runs very smooth even at a very slow speed. The only thing I can think of is that the motor might be a different production. I don't think they're geared different and I don't see any articles about these machines being geared differently.
    I guess I could try replacing the motor?
    Thanks for your hellp.
  2. Herc Driver
    Herc Driver Active Member
    I run a straight DC operation to and have found differences in Kato engine speeds. I don't have the time or inclination to start swapping out motors - so when I hook them together in a consist, I try to let the faster diesel pull the cars and the slower one lead. But I always look at the coupler between the diesels...if the trailing diesel is pushing the leading diesel's coupler, I either add more weight to the entire train to "weigh down" the faster one or I choose another diesel match-up.
  3. Inder
    Inder New Member
    Thank you for your help.
    I was gonna do the opposite and have the faster one pull the slower one but after reading your post I can see why my idea doesn't make sense and your idea is more sound. I will do that.
  4. BNSFtheLeader
    BNSFtheLeader Member
    I have had this problem before when buying used engines one situation for instance was 3 C44-9's that ran quite different than each other so I took some model grease and oil and greased the Brass flywheel gear and the truck gears ( very liberally ) and oiled the flywheel gear bearings. the grease being so thick bogs down on the motor and after that they ran right with the new one again....
    Hope this helps....
