just got new engine
Discussion in 'RC General & Getting Started' started by hom sha bom, Apr 8, 2004.
Thread Status:
  1. hom sha bom
    hom sha bom New Member
    O.K. so i just got a HYPER .21 turbo engine for my OFNA 1/8 scale. i started taking the parts off of my OFNA 3.5 engine to put on the HYPER. but i cant get the flywheel off. can some one give me some tips or suggestions on how to do this? thanx
  2. mastmec
    mastmec Member
    Easiest and safest is to use a battery terminal puller for auto batteries at a auto parts store for a couple of bucks. Just put it on and twist, it will pop off. Or use a small hammer and tap it all around, but be carful not to damage the flywheel.
  3. hom sha bom
    yeah the last thing that i want to do is damage the flywheel and have spend even more money than i should have to. thanx for the info
  4. rcosmax
    rcosmax Member
    you can buy a flywheel puller for cheap at most local hobby shops. then you are certain you wont damage it.
  5. timrock
    timrock Active Member
    bad idea to tap it with a hammer.get a puller designed for it as rcsox says.you can get one at a hobby shop.he know what he is talking about.mastmec is a moron lol.that flywheel needs to be pulled off evenly or it will be damadged.do not hit it with a hammer lol
  6. timrock
    it is my job to babysit mastmec and make sure he doesnt give bad addvice.
  7. mastmec
    mastmec Member
    The only reason you follow me around like a shadow on this forum Tim, is so you can learn things and then go to other forums and then you sound like you do actually have some intelligence.
  8. monsterrcbuilder04
    actually if he is using what you say and in turn learning it then he does have inteligence.
  9. timrock
    i have intelligence.but i am not doing that.mastmec is a nasty mean person.he has shown that to me so i like to get on his case.also he gave wrong and inexperienced addvice to people.so somone needs to babysit him so they gave me the job.
    i bet he bullies the other kids in his school too.
  10. mastmec
    mastmec Member
    OK Tim, again, what bad advice did I give? You keep bringing this up, but never prove anything.
  11. timrock
    i proved it every time.then you deleted your posts so now i started quoting you and you said that i changed what you said which is not true.so you need a babysitter.
    and once i feel that you can go out on your own i will say ok.
  12. monsterrcbuilder04
    guys these forums are not for you 2 to fight they are to help peple. if you want to fight pm each other or something
  13. timrock
    thats what i have been saying.but this kid keeps it up.it is bazar
  14. monsterrcbuilder04
    you can stop it to. just dont reply to him. ignore it.
  15. dj6666969
    dj6666969 Active Member
    OK YOU 2 you can use a hammer to get it off BUT USE A RUBBER HAMMER and it should be ok just tap it all the way around and it should come off or the terminal/puller thing will also work.
Thread Status:
