Is gravel a good material for a road bed?
Nomad
1,570
Elks Plain, Washington
Mike, the cork roadbed is used to help reduce track noise and imitate the look of a real mainline railroad by having a sloped shoulder.
That said, you can cut roadbed out of homosote or even plywood ( if your not worried about the noise ) and slope the shoulder. The "gravel" is used later after the track is layed to imitate the ballast.
Also, if you are modeling a small branch line railroad or such, you can lay the track right on top of your tabletop since that would not have the well maintained ballasting. Hope this makes sense.:confused:
Loren
green_elite_cab
Keep It Moving!
Apr 4, 2005
1,876
Hainesport NJ
You can probably just cut it. If its actual model railroad cork, then it splits down the middle in a sloped fashion. you need to two pieces to help you make curves easier.
N
nachoman
It probably cuts easily with a utility knife as long as it is not dried out. You want something about 3/16-1/4 inch thick. (Or about 5mm).
Kevin
Glen Haasdyk
1,283
Kelowna, BC
I bought cork in sheet from a home store and cut in into strips to make the roadbed. Turned on alot cheaper than building the ready-made cork. I angled it with the untility knife like was mentioned earlier. You could possibly cut the cork a little wider and angle it after you've laid it down on the layout. that might give you a slight advatange to make a realitsic slope.
Nomad
1,570
Everybody,s right. Sorry I forgot to mention that:eek:ops:. It would be best to cut the cork at a angle with a knife and then smooth the edges with sandpaper if needed. I think plaster would leave to rough a finish to be realistic.
Loren
KCS
443
Shreveport, LA.
Mike, I don't recommended using just any kinda gravel. Some guy's do even sifting dirt for landscape but again, not recommended. The ballast that you buy has undergone a wash process of chemical to clean it and then baked to dry and kill any last living parisites that might be living in it then bagged and shipped. That's just to make a long story short. The parasites can grow and cause discoloration over time or any number of thing's. I saw one layout that it was done with dirt and after a few year's in a different enviorment started growning a white velvet looking mold that was unsightly. Just my $.02 of knowledge.
4,501
Lakewood, Ca.
You could just cut the cork vertically, and then fill with ballast to make the slope. If you can't get regular model railroad ballast locally where you live, I think you could use dirt or sand if you take a few precautions. First I would sift any material you get to get the size down to "scale." Second, drag a magnet around through the loose ballast material, and discard anything that sticks to the magnet. Repeat that process until you don't get anything sticking to the magnet. Third, chlorine bleach will kill almost anything, so wash your material in chlorine & water. You may want to test it first to make sure the chlorine doesn't bleach out color. Finally, put the ballast material in a pan and put it in the oven and bake it above 300 degrees for an hour or so and then let it cool before using it. If anything lives through that, RUN! You can't kill it!
Mountain Man
1,607
But if that is all you can get - MICROWAVE. One minute on high will kill anything.
